> If so, did you run a wire through the fluid return hole in the master
> cylinder? It's covered by a little stamped steel piece that keeps
> fluid from spraying up when the lever is released. It's a very small
> hole, you need to pull off that piece, and poke a small wire through
> the hole to get the congealed brake fluid out of there that is keeping
> fluid pressure in the front brake lines.
why did they design it that way?
what problem would be caused if the stamped piece is removed and the
fluid "sprays" inside the closed reservoiur?
Mark
