Wibb <(E-Mail Removed)> wrote:
> In the hand book it says when you remove the oil drain plug there should be
> a "sealing washer"
> When I removed the drain plug I never saw this washer.
The 'washer' may be an aluminium or copper washer that was attached to
the drain plug.As the plug is tightened, the washer deforms
slightly,moulding itself to the drain plug, so the washer and drain plug
appear to be 'one'.
Alan.
Change the 'minus' to 'plus' to reply by e-mail.
http://www.dvatc.co.uk - Off-road Cycling in the North Midlands.
