On Aug 20, 5:52*am, Mark Olson <ols...@tiny.invalid> wrote:
> Dan Barnhill wrote:
> > Hey all,
> > Have an 84 Yamaha Venture. Has this quirk where every so often when
> > firing up the bike - *when the start button is pressed, the power to
> > the entire bike shuts off. Dash goes blank as if the battery had been
> > removed.
> > Popping the leads off the battery and then reconnecting solves the
> > problem and the bike then starts up fine.
> > Yesterday, however, power to the entire bike cut out without any
> > prompting from me while I was full throttle down the highway. Had to
> > coast onto a thin left shoulder of a busy bridge with cagers climbing
> > up my tailpipe.
> > Again, I popped the battery leads, reconnected and was able to start
> > the bike. Then went 300 more miles on the day without any trouble.
> > Before I start ripping things apart - does anyone have any ideas as to
> > what's going on?
> Either an intermittent open inside the battery (is it a Yuasa by any
> chance?) or a loose cable connection, removing and reconnecting the
> leads is irrelevant- the key is you wiggle things around when you R&R
> the leads.
Take a look at the other ends of the battery cables.
If they respond well to wiggling at the battery end,
my bet is a loose connection at the other end.
