Thanks for everyone's answers.
Autocom definitely has a system that works, but it's their high-end model,
which is about $450/ea, ouch! Two of those is tough to stomach.
Unfortunately their low-end model doesn't have VOX, and their middle model
requires external power. Almost like they know that darn near everyone's
going to want those in the high-end model:-]
-pete
"Dave HD" <davehd-(E-Mail Removed)> wrote in message
news:8eSdnesxRM0a_xjcRVn-(E-Mail Removed)...
> Try the Autocom systems. There are different units for different needs
> and budgets. I think that there's one that meets your specs. I have had
> one on my bike for about 2 years and love it. www.autocom.com (I think
> that's correct).
> Best Regards,
> Davehd
> "'Lefty'" <(E-Mail Removed)> wrote in message
> news:(E-Mail Removed)...
>> "Pete Grey" <(E-Mail Removed)> wrote in message
>> news:4182abb2$(E-Mail Removed)...
>> | Requirements: VOX, unit is self-sufficient (no bike attachments), able
>> to
>> | communicate to at least 65mph, full-face or flip-up helmet.
>> | Trying to figure out what the best deal is out there, say < $250/unit.
>> | Thanks, -pete
>> Something to consider: Amateur <Ham> Radio.
>> The FCC has dropped the morse-code requirement for a "Technician"
>> license, giving you access
>> to Everything above 30 Mhz. That includes 2-meters and "repeaters", some
>> with "Phone patches".
>> Anyone who can figure out wiring on a bike can pass the BASIC test for
>> Technician. Exams for the
>> license are givin by "Volunteer Examiner Teams", which are set up all
>> over.
>> (Ask at a Radio Shack or go
>> to www.arrl.org) License manuals are readily available.
>> Ham gear is All Over The Place on eBay, with "Swap Meets" in various
>> regions too. Used is Much
>> Cheaper than new, and as it's all "Solid State Electronics", no tubes to
>> replace.
>> Ham Radio Clubs are another way for a "Free Look" into the hobby.
>> You say thats a whole lot for a motorcycle comm system... It's more
>> than
>> just a cell phone.
>> On the bike, you'll need good headphone speakers, and probably a
>> noise-cancelling mike, as well
>> as a big styrafoam ball to knock the wind noise down, or try a
>> throat-mike
>> pickup. None of these will
>> provide much fidelity. (Put the speakers inside your helmet, not in your
>> ears. You need to Hear The Road
>> to Survive...)
>> One other trick is either FRS or CB for the radio-end.
>> On the "power from the bike", look for some "Ferrite Beads" to put on
>> the
>> power lines. Alternators
>> make lots of noise, and a bike's regulator usually isn't designed to
>> filter
>> this well. Cheap way around,
>> use a battery for the radio, and charge the battery from the bike when
>> you're not using the radio. You'll
>> still have the "Radiated Noise", but if there isn't a wire passing the
>> noise, less engine electrical noise.
>> Another way around the noise is to use FM vs AM-SSB, and turn the squelch
>> up.
>> Good Luck, Lefty
