Motorbike Forums
Reply
Thread Tools Display Modes
Blinker ghost
Harold Gailey
Guest
Posts: n/a
      12-27-2009, 11:15 PM
Had a blinker ghost in the left blinker of my 02 FXDX for about a week. The
blinker would come on as soon as I turned on the ignition and would only
sometimes self cancel. Sometimes I could manually cancel it by punching the
left switch, sometimes not. Sometimes I could cancel it punching the right
switch, sometimes that would activate the four-ways. Some days were worse
than others with me having to split concentration between riding and keeping
my signaling accurate way too much. I was hoping it was just water in the
switch and eventually it would dry up and go away. I decided to open the
switch housing yesterday to see what was what. I loosened the screws holding
the clutch lever against the switch housing and moved it away from the
switch housing then removed the switch housing screws and peeled it off the
handlebars. I put my key in and turned the ignition on. No blinking. I hit
the switch and the blinker came on. I hit it again it went off. I repeated
this a number of times and it seemed the ghost was banished. I reassembled
the housing and retightened the clutch lever assembly and retested the
switch operation. Working like a charm so far. This is the first repair I
have attempted on this bike. The only other work it's required was bearings
in the frame neck and usual maintenance items like tires and brakes. I
haven't even had to replace a light bulb yet. This has been a most excellent
and dependable machine for nearly 50,000 miles. I am very pleased with this
bike.
74 CB 450 - STOLEN; 74 Z1 900 - TRADED; 76 FX 1200 - STOLEN; 78 FX(E) 86 CI
DAILY RIDER NICE WEATHER; 02 FXDX 88 CI DAILY RIDER OTHER WEATHER
louie
Guest
Posts: n/a
      12-28-2009, 04:26 PM
"Harold Gailey" <(E-Mail Removed)> wrote in message
news:2MSZm.16149$(E-Mail Removed)...
> The blinker would come on as soon as I turned on the ignition and would
> only sometimes self cancel. Sometimes I could manually cancel it by
> punching the left switch, sometimes not. Sometimes I could cancel it
> punching the right switch, sometimes that would activate the four-ways.
> Some days were worse than others with me having to split concentration
> between riding and keeping my signaling accurate way too much. I was
> hoping it was just water in the switch and eventually it would dry up and
> go away. I decided to open the switch housing yesterday to see what was
> what. I loosened the screws holding the clutch lever against the switch
> housing and moved it away from the switch housing then removed the switch
> housing screws and peeled it off the handlebars. I put my key in and
> turned the ignition on. No blinking. I hit the switch and the blinker came
> on. I hit it again it went off. I repeated this a number of times and it
> seemed the ghost was banished. I reassembled the housing and retightened
> the clutch lever assembly and retested the switch operation. Working like
> a charm so far. This is the first repair I have attempted on this bike.
> The only other work it's required was bearings in the frame neck and usual
> maintenance items like tires and brakes. I haven't even had to replace a
> light bulb yet. This has been a most excellent and dependable machine for
> nearly 50,000 miles. I am very pleased with this bike.
> CI
Now you're talking Harold.
Welcome aboard!
...louie
Harold Gailey
Guest
Posts: n/a
      12-29-2009, 12:56 AM
"Edward Grant" <(E-Mail Removed)> wrote in message
news:2009122723070116807-egrant@sbcglobalnet...
>> The
>> the
>> right
>> keeping
>> holding
>> the
>> hit
>> repeated
>> reassembled
>> bearings
>> excellent
>> this
>> bike.
> Probably just enough dirt and grime in there to cause an intermittent
> short. Probably
> would be a good idea to clean the switches every year along with changing
> the smoke
> detector batteries. :-)
> Ed
I had some contact cleaner around here some place. I was going to flush the
switch out good once I got in there but after seeing it blinking correctly
after just opening the housing I didn't bother trying to find the cleaner.
Harold Gailey
Guest
Posts: n/a
      12-29-2009, 12:58 AM
"louie" <(E-Mail Removed)> wrote in message
news:hhapoe$65k$(E-Mail Removed)...
>> came on. I hit it again it went off. I repeated this a number of times
>> and it seemed the ghost was banished. I reassembled the housing and
>> retightened the clutch lever assembly and retested the switch operation.
>> Working like a charm so far. This is the first repair I have attempted on
>> this bike. The only other work it's required was bearings in the frame
>> neck and usual maintenance items like tires and brakes. I haven't even
>> had to replace a light bulb yet. This has been a most excellent and
>> bike.
>> CI
> Welcome aboard!
> ..louie
Thanks Louie. My blinker still turns itself on when I turn on the ignition
but so far today it did not come on while riding.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Blinker wiring question - how to get blinkers to stay ON and flashOFF? Masospaghetti Motorbike Technical Discussion 8 07-09-2005 04:48 PM
I've got my blinker on - I've got the right of way! James Mayfield Australian Motorcycles 109 08-19-2004 06:10 AM
1 2 3 4 5 6 7 8 9
