Motorbike Forums
Reply
Thread Tools Display Modes
Brake caliper with approx. 75 mm hole distance??
TAV
Guest
Posts: n/a
      12-25-2011, 04:04 PM
Hello
I have an old USD Front fork. The mount for the brake caliper is
approximately 75 mm. The fork origins from an Offroad or an endurance bike.
Can anyone tell me from wich bike the fork might come? I'm having trouble
finding a brake caliper.
BR. Tor, Denmark
George W Frost
Guest
Posts: n/a
      12-27-2011, 11:25 PM
"TAV" <(E-Mail Removed)> wrote in message
news:4ef757ae$0$287$(E-Mail Removed)...
> Hello
> bike. Can anyone tell me from wich bike the fork might come? I'm having
> trouble finding a brake caliper.
> BR. Tor, Denmark
Unless you have the other one to match, it will be of no use
While they do have certain advantages in high speed racing, ordinary use has
none.
Harley use USD forks but I think it is for aesthetic value only
George W Frost
Guest
Posts: n/a
      12-28-2011, 10:14 AM
"Jordan" <(E-Mail Removed)> wrote in message
news:BrCKq.959$%(E-Mail Removed) d.com...
>> has
>> none.
> You don't think USD forks are better than right side ups, on street bikes?
> They should be stronger, less likely to bend in a bingle, surely?
I have never ridden a bike with the intention of having a bingle, so I don't
look forward to that event,
the USD forks have the advantage when racing of holding a corner better at
high speed because of less stress
CrazyCam
Guest
Posts: n/a
      12-28-2011, 07:42 PM
On 12/28/11 9:45 PM, Jordan wrote:
<snip>
> bikes? They should be stronger, less likely to bend in a bingle, surely?
I noticed that the USD forks, on the likes of the 675 Daytona or Street
Triple, seem to be sufficiently stiff that, in a front end crash, they
can crack the frame at the steering head, making the bike a stat write off.
regards,
CrazyCam
Nev..
Guest
Posts: n/a
      12-31-2011, 02:50 AM
>> use has
>> none.
You can offset the extra expense of bent forks in a bingle by not
crashing, or if that's too difficult, by doing so in such a way that
some other part of the bike takes the brunt of the impact.
Nev..
Zebee Johnstone
Guest
Posts: n/a
      12-31-2011, 03:09 AM
In aus.motorcycles on Sat, 31 Dec 2011 14:50:40 +1100
>>> use has
>>> none.
I have usually done it by throwing myself under the bike to save it.
Zebee
Diogenes
Guest
Posts: n/a
      01-01-2012, 02:11 AM
>> crashing
>I wish I knew how to do that. When I think I'm experienced enough
>never to crash again, is usually just before I do.
Could that be because when you think you're the bees' knees on the
experience level you ride harder thereby pushing the envelope further
only to discover that you weren't experienced enough for that harder
level of riding?
I think I saw a guy like that running wide on a bend and nearly
cleaning me up as I was coming the other way. I mumbled "I hate
hoons" into my helmet and growled a lot for the next few k's. :-(
Fraser Johnston
Guest
Posts: n/a
      01-03-2012, 05:28 AM
>>>> use has
>>>> none.
I had to lay it down..... : )
Fraser
Fraser Johnston
Guest
Posts: n/a
      01-03-2012, 05:29 AM
On 1/01/12 11:11 AM, Diogenes wrote:
>>> crashing
> level of riding?
Have you stopped nodding at sportsbike riders yet? ; )
Fraser
BT Humble
Guest
Posts: n/a
      01-03-2012, 11:36 PM
Jordan <ko...@koora.net> wrote:
> Wow, the frame is weaker than the wheel? Or maybe it got crushed first -
> a big accident!
> Standard type forks bend before the wheel does.
While waiting to be served at the wreckers this morning, I had a good
look at a ZX6R that had been run into something rather hard (I later
learned that it had T-boned a car). Snapped forks, bent front wheel,
squashed radiator and flattened exhaust headers.
What really made me wince was the huge dent that the rider had made in
the fuel tank with his testicles.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
XT600r brembo brake caliper mark UK Motorcycles 11 06-09-2011 06:36 PM
Brembo brake caliper seals Lozzo UK Motorcycles 1 01-29-2011 06:33 PM
cb750 master brake cylinder assembly Dave Motorbike Technical Discussion 4 10-18-2010 05:25 AM
Liam Magee PaulpULVITZKA Australian Motorcycles 2 06-13-2010 12:27 PM
Brake caliper seals; brembo stephen.packer@gonemail.com UK Motorcycles 3 03-14-2010 03:24 PM
1 2 3 4 5 6 7 8 9
