Motorbike Forums
Reply
Thread Tools Display Modes
Buying a zzr 250. Problems?
Psi
Guest
Posts: n/a
      08-28-2003, 03:12 PM
Have decided to buy a zzr 250 as a learners bike, probably second hand,
so...
Any things i should look out for, specific to this bike, in terms of wear?
Any components known to have a relatively short lifespan?
This is the last line of questioning before I go hunting, i've talked to
some ex riders and other motorcycle "home mechanics"...hehe....just seeing
if theres a last minute piece of wisdom out there.
iCentral
Guest
Posts: n/a
      08-28-2003, 03:28 PM
Drop it and you'll realise why learners shouldn't ride plastic bikes.
troy
"Psi" <(E-Mail Removed)> wrote in message
news:vZo3b.475$(E-Mail Removed)...
> so...
sharkey
Guest
Posts: n/a
      08-28-2003, 09:11 PM
Sayeth Chris Cavin <(E-Mail Removed)>:
> You know, sometimes you just can't get a break in this news group. FINALLY
> somebody posts about getting a learner bike that is 100% appropriate for
> learning on and what happens? He gets criticized for picking something with
> too much plastic. Sheesh.
Well, he's right though. Buy a GPX250 instead, same engine but less
curvy plastics to ruin :-)
-----sharks
Du verschwendest Übertragungskapazitäten.
FuTAnT
Guest
Posts: n/a
      08-28-2003, 10:23 PM
>>> bikes.
>> FINALLY somebody posts about getting a learner bike that is 100%
>> appropriate for learning on and what happens? He gets criticized
>> for picking something with too much plastic. Sheesh.
> -----sharks
Or you could just not drop it ... not all learners drop their bikes ... or
should be expected too!
Cam
'00 ZX6R
knobdoodle
Guest
Posts: n/a
      08-28-2003, 11:42 PM
You're right; just because 99.8% do it's no reason to take precautions
against you doing the same thing.....
Clem
Dane
Guest
Posts: n/a
      08-28-2003, 11:44 PM
buy a gpx250 and take the fairings off then
ps. drop it and you'll realise why learners shouldnt ride without
training wheels and a little front mounted pink wicker basket with a
left bar mounted bell with themselves fully wrapped in cotten wool.
fwiw i slayed my old gpx on the putty road and it not only lived to tell
the tale but it got back home in mostly one piece. They're tough as all
dane
> -----sharks
Jules
Guest
Posts: n/a
      08-29-2003, 02:23 AM
It's a great bike and you will love it.
Don't worry about all the rubbish you read here ;-)
> so...
BT Humble
Guest
Posts: n/a
      08-29-2003, 05:41 AM
Yup! The narrower fairing means that you break footpeg brackets and
handlebars instead! ;-)
FuTAnT
Guest
Posts: n/a
      08-29-2003, 07:02 AM
knobdoodle wrote:
>> ... or should be expected too!
> Clem
Come on ... give em more credit ... it's not that high!
Cam
'00 ZX6R
Psi
Guest
Posts: n/a
      08-29-2003, 12:37 PM
Cheers.
Didn't know that particular sellers trick
"Dale Porter" <(E-Mail Removed)> wrote in message
news:jjE3b.320$(E-Mail Removed)...
> > so...
wear?
seeing
> As with all bikes, check for unusual wear. Things like pitted and damaged
> chrome on the front forks. These can destroy fork seals. Also check the
fork
> seals for wear and/or signs of leakage.
> If it has rubber hoses for brake lines and cooling systems, check to make
> sure they aren't cracking or going too hard.
> If you get to see bits of the frame, look for signs of cracked paint
and/or
> stress marks near joins.
> If you can, try to get the bike started from dead cold. Most sellers will
> try to make sure the engine has been warmed up a little before you arrive
> (assuming they know you're coming) so this is going to be tricky. It can
> show up things like smoky engines, and if there's a problem with the
tuning
> with the choke applied. Not neccesarily a biggie this second one, but can
be
> an indicator of some work needed to get it running nicely.
> Whilst the engine is running, place your hand directly behind the exhaust.
> If there are little black, oily spots on your hand, that's not a good
sign.
> Does it spit oil only until it's been warmed up?
> Get a mate to follow you on another bike or in a car if you take it for a
> spin to look for smoke puffs under acceleration.
> Dale Porter
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Advice on buying a 50s BMW Newt Bridges Classic Motorbikes 2 10-26-2008 07:10 PM
400/4 - what to look for when buying? FrJack @ work Classic Motorbikes 3 01-04-2007 10:43 PM
Buying a Trike Ted Taylor Motorbike Technical Discussion 1 05-11-2006 03:14 PM
1 2 3 4 5 6 7 8 9
