Motorbike Forums
Reply
Thread Tools Display Modes
Changes in the 2009 Australian road rules regarding navigation equipment.
John Tserkezis
Guest
Posts: n/a
      02-19-2010, 06:29 AM
I've just properly read Part 18, section 299 of the 2009 Australian
Road Rules, and the bit about visual displays not allowable.
There is an exception in place for "driver's aids", of which navigation
is one example.
The 2008 road rules (of which NSW currently follows) says (in part):
(2) This rule does not apply to the driver if:
(b) the visual display unit is, or is part of, a driver’s aid, or
Fine, now the 2009 ARR says (again in part):
(b) the vehicle is not a motor bike and the visual display
unit is, or is part of, a driver’s aid and either –
It's the motor bike bike I'm interested in. This implies that the 2009
exception does NOT apply if the vehicle is a motor bike. That is, no
motor bikes are allowed SatNav devices at all, if (or when) NSW starts
following the 2009 revision.
Again, I know this does NOT CURRENTLY apply, I'm just concerned they
may sneak this one in if (or when) they do apply it.
Marty H
Guest
Posts: n/a
      02-19-2010, 08:07 AM
On Feb 19, 6:29*pm, John Tserkezis
<j...@techniciansyndrome.org.invalid> wrote:
> *I've just properly read Part 18, section 299 of the 2009 Australian
> *There is an exception in place for "driver's aids", of which navigation
> is one example.
> *The 2008 road rules (of which NSW currently follows) says (in part):
> (2) *This rule does not apply to the driver if:
> (b) *the visual display unit is, or is part of, a driver’s aid, or
> *It's the motor bike bike I'm interested in. *This implies that the 2009
> exception does NOT apply if the vehicle is a motor bike. *That is, no
> *Again, I know this does NOT CURRENTLY apply, I'm just concerned they
I could be wrong but if the rules are the same as the Vicroads, which
I believe they are now cos every state is suppose to be standardised
the Exemption is about
The rule relating to "securing" visual display units does not apply to
motorcycles.
The visual display unit just doesn't have to be an integrated part of
the vehicle design, or secured in a commercially designed holder,
which is fixed to the vehicle as it does for cars
i.e a gps can sit in the clear part of your tank bag on a motorcycle,
but on a car it cant sit in your centre console
in other words...its a little win for us
mh
Marty H
Guest
Posts: n/a
      02-19-2010, 08:09 AM
> is one example.
also, it might be wise to post a link to the whole rule
here is the pricktoads one
http://www.vicroads.vic.gov.au/NR/rd...PhonesVDUs.pdf
Andrew
Guest
Posts: n/a
      02-19-2010, 08:34 AM
>> navigation
>> is one example.
>> (2) This rule does not apply to the driver if: (b) the visual display
>> (2) This rule does not apply to the driver if: (b) the vehicle is not a
>> motor bike and the visual display unit is, or is part of, a driver’s
>> aid and either –
>> 2009
> Without posting more of (or the whole section) of the rules it's hard to
> tell in what context they're using it.. but I think you've got it wrong.
> They are not excluding satnavs for motorcycles, they're excluding
> motorcyclists from a restriction which is intended to be imposed on
> displays intended for other drivers only, not motorcyclists.
> Nev..
> '08 DL1000K8
Correct. Satnav for bikes is excluded from the restriction. However, the
rest of the regulation is objectionable. My mobile phone provides a (not
very good) GPS function and comes with a doover to suck-stick it to the
windscreen, but I don't think that makes it a driver's aid.
Regards
Andrew
John Tserkezis
Guest
Posts: n/a
      02-19-2010, 09:17 AM
Ah, that's a lot clearer now. The wording could have been taken in a
couple of different ways.
The documents I used where:
Australian Road rules 2009:
<http://www.ntc.gov.au/filemedia/Reports/ARR_February_2009_final.pdf>
Australian Road rules 2008:
<http://www.austlii.edu.au/au/legis/nsw/consol_reg/rr2008104/>
Part 18, Section 299 "Television receivers and visual display units in
motor vehicles" is the part of interest.
Both are very similar, with the 2009 revision stating the Motor bike
exception, the driver's aid must either be a factory install or fastened
to the vehicle with a commercially available holder designed for the
purpose, and a more clear exception to allow for displays in Police and
emergency vehicles.
The vicroads addition you linked to, pretty much paraphrases that.
My confusion stems from the boolean logic wording they used.
299(2)(b) says, if NOT a motorbike AND display is an aid, then the
exception applies.
Since we're talking about bikes, 299(2)(b) cannot apply, so there is no
exception for that condition (bikes).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
1 2 3 4 5 6 7 8 9
