Nomen Nescio wrote:
> If the battery electrolyte could be made dark with some kind of
> non-reactive colorant, it might be easier to visualize its level. I
find
> it very difficult to maintain it between the two lines inscribed on
the
> translucent poly case because there just isn't enough contrast
between the
> colorless electrolyte and the case.
> Does anybody know if there is some sort of dye that might be added to
> accomplish this?
> Alternatively, are motorcycle batteries available as a
low-maintenance
> type, gel-cell, which negates having to periodically check the
electrolyte
> and replacing lost water as needed?
You can always use a piece of plastic straw as a dipstick.
Generally, I figure if the plates are well covered the level's
about right.
