Motorbike Forums
Reply
Thread Tools Display Modes
ECUs - engine brains
fragmented
Guest
Posts: n/a
      11-22-2008, 12:02 PM
Slow things.
Put key in, press start button ASAP, engine splutters into life, coughs
a few times and stops.
Turn ignition off, turn back on, wait a few seconds, hit starter button,
engine cranks a few times and then starts, and then chucks out a load of
oil smoke.
I've had this happen to me on the Porsche, just happened on the ZX10,
and also happened to the Suzuki VStrom, all injection engines, all have
ECUs with in-built immobilisers, all have cats that I bet the ECU is
programmed to protect.
I phoned the garage for help when the Boxster did it as it just wasn't
starting, they said "keep turning it over, it'll sort itself out" and it
did after about 20 seconds, turned on 1 cylinder, then 2nd, 3rd, etc.
Clever little diagnostic routine.
Cause : in all cases I didn't wait for the ECU to do its power on
initialisation before I tried to start the engine. I can understand that
bit, the ECU doesn't get a chance to read any of the sensors, so
probably just tries to start it with the defaults of a normal hot
engine, which obviously doesn't work and it dies. (and then ECU then
goes "oops, I'm going to set diagnostic mode next time I start" which is
why it takes a bit to start next time, ~20 secs+ in the case of the
Porsche)
What I'm guessing about is how the oil gets sucked into the combustion
chamber? ECU thinks somethings wrong because engines mis firing like mad
and exhaust gasses are way out of spec, turns off fuel and ignition
(don't know if they can turn off the hydraulic valves too?), so vaccum
builds up in cylinder and sucks a little bit of oil past the
piston/rings?
Anyway, I must beat my brain into remembering to "Let the bloody rev
needle do its flick up and down fully before hitting starter button, it
does it for a reason!"
fragmented
Eiron
Guest
Posts: n/a
      11-22-2008, 12:24 PM
fragmented wrote:
> Slow things.
> oil smoke.
> Porsche)
> piston/rings?
It beats pressing the tickler button on both carbs until petrol pours
from the overflow
after remembering to remove the bath plugs from the bellmouths before
pressing
the starter button. :-)
Eiron.
Timo Geusch
Guest
Posts: n/a
      11-22-2008, 12:39 PM
fragmented <(E-Mail Removed)> writes:
> Slow things.
Do they display Windows Vista logos when you're booting the car?
> chamber?
Unlikely, I'd day.
Nope.
> so vaccum
> piston/rings?
I'd doubt that. Past the valve guides, possible. But if it sucking via
the rings you might want to let some air into the engine at one point
Morini Corsaro 125 | CB450K4 | XL250 Motosport | 900SSD | R1150RT
Laverda SF2 | Harley FXD BOTAFOF #33 TWA#10
The UKRM FAQ: http://www.ukrm.net/faq/index.html
"Je profite du paysage" - Joe Bar
fragmented
Guest
Posts: n/a
      11-22-2008, 01:17 PM
'Eiron' wrote...>
> from the overflow
> pressing
Heh, yes its a definite improvement over doing that
Bath plugs in the bellmouths? Is that to stop dirt or insects or mice?
fragmented
fragmented
Guest
Posts: n/a
      11-22-2008, 01:39 PM
'Timo Geusch' wrote...>
coughs
If *any* vehicle showed a Microsoft logo that looked a bit XP or Vista
like I'd run for my life!
(I know quite a few use MS Embedded, but one has to hope they've done
the beta testing *before* releasing it, unlike Windows)
combustion
> > chamber?
> Unlikely, I'd day.
Well it was definitely blue/white oil smoke, so its oil, and its being
burned off.
Perfect now, let it cool down, start it (properly), not a trace of
smoke.
> Nope.
Maybe the ECU shuts the secondary throttle butterfly as well as cutting
off the fuel, that will create a nice vaccuum in the chambers?
Haven't a clue really
fragmented
Catman
Guest
Posts: n/a
      11-22-2008, 02:03 PM
fragmented wrote:
<snip>
> Porsche)
That would be *really* dumb IMHO. The Sprint simply will not turn the
starter motor until it's ready. Why on earth would they let a potential
situation like describe be possible?
www.cuore-sportivo.co.uk
Eiron
Guest
Posts: n/a
      11-22-2008, 02:59 PM
fragmented wrote:
> 'Eiron' wrote...>
>> from the overflow
>> pressing
Rain, while your café racer is parked outside the café.
Eiron.
Fr Jack
Guest
Posts: n/a
      11-22-2008, 03:00 PM
In the case of some bellmouths, it was to stop dogs and small
children...
Fr. Jack
Life is short and love is always over in the morning.
Pete Fisher
Guest
Posts: n/a
      11-22-2008, 03:02 PM
In communiqué <(E-Mail Removed)>, Fr Jack
<(E-Mail Removed)> cast forth these pearls of wisdom
>children...
Also a surprisingly effective primitive anti ****wit theft device. See
my posting a while back about my old AJS 16C.
| Pete Fisher at Home: (E-Mail Removed) |
The Older Gentleman
Guest
Posts: n/a
      11-22-2008, 03:49 PM
ITYM 'broken down in Wales'.
BMW K1100LT Ducati 750SS Yamaha XTZ660 Tenere Honda CB400F CB250N SH50
chateau dot murray at idnet dot com
"What you're proposing to do will involve a lot of time
and hassle for no tangible benefit."
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
SEO Services - Search Engine Optimization – SEM – Search Engine Submission hitech UK Motorcycles 1 07-05-2008 08:20 PM
SEO Services - Search Engine Optimization – SEM – Search Engine Submission hitech UK Motorcycles 0 07-05-2008 12:10 PM
Engine assembly and how an engine works. Cab UK Motorcycles 9 11-04-2006 09:54 PM
Brains of Haynes R L Driver Classic Motorbikes 12 09-28-2003 11:20 PM
1 2 3 4 5 6 7 8 9
