Motorbike Forums
Reply
Thread Tools Display Modes
Engine Sprocket Removal on Panhead
derch
Guest
Posts: n/a
      06-14-2009, 04:18 PM
Hey all. A round for the house.
I am attempting to remove my engine sprocket, primary chain, and
clutch hub off my 48 Panhead. The engine sprocket won't budge. Is
there enough room to attach a puller on the sprocket without damaging
the primary chain or should I just heat the sprocket? Thanks all.
frijoli
Guest
Posts: n/a
      06-14-2009, 05:56 PM
I wouldn't heat it. Is this typically a press fit on the
shaft, or is it tapered? Try PB Blaster penetrant. It works
very well on stuck parts.
Clay
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine removal...pain? stuey.brown@gmail.com UK Motorcycles 16 08-18-2008 11:34 AM
ZX10R Front Sprocket Removal RichardA UK Motorcycles 41 07-29-2008 05:25 AM
Yamaha XT600 Front Sprocket Removal mazdaman851 Motorbike Technical Discussion 15 02-03-2005 09:52 PM
Loc-Tight on engine sprocket nut? hcbowman@gmail.com Motorbike Technical Discussion 2 10-13-2004 08:54 PM
Engine removal - NTV 650 Klaatu UK Motorcycles 33 01-02-2004 07:44 PM
1 2 3 4 5 6 7 8 9
