Motorbike Forums
Reply
Thread Tools Display Modes
FLT Leaking Shift Shaft
derch
Guest
Posts: n/a
      05-21-2009, 02:56 PM
Hey All,
Hope all are well. A round for the house!!!
I am having a problem with my 2001 Roadking. It seems that there is a
leak at the base of my shifter shaft. The manual shows a washer and
retaining ring on the shaft. I am assuming the retaining ring is the
source of the leak. Does anyone know if I can get to this without
removing the inner and outer primary? There is some room however, I
can't tell if there is enough room to actually remove the shift
linkage arm. Thanks all....
Phil Boutros
Guest
Posts: n/a
      05-30-2009, 05:57 PM
Inner and outer primary has to come out. Behind the snap ring
and washer, there is a seal. It needs to be replaced. While you're
there, check all tranny seals (the mainshaft seal requires a special
tool to remove and re-install the primary bearing inner race before
you can get to it).
Put tape over the shifter shaft before putting in a new seal,
or the splines will wreck it, meaning you'll have to go back in there
again.
Phil
AH#61 Wolf#14 BS#89 bus#1 CCB#1 SENS KOTC#4 (E-Mail Removed)
http://ah61.com http://philb.ca EKIII rides with me. http://eddiekieger.com
WWJD? JWRTFM.
hackerkey://v4sw5CU$hw7ln4pr7ck4ma9u7LMw2m7l7Si982Ct4b8en6a3Xs 7r2p-5.38/-8.77g4
rricciardi@cfl.rr.com
Guest
Posts: n/a
      06-01-2009, 11:27 AM
On May 30, 1:57*pm, Phil Boutros <ph...@total.net> wrote:
> derch <rriccia...@cfl.rr.com> wrote:
> > I am having a problem with my 2001 Roadking. *It seems that there is a
> > leak at the base of my shifter shaft. *The manual shows a washer and
> > retaining ring on the shaft. *I am assuming the retaining ring is the
> > source of the leak. *Does anyone know if I can get to this without
> * * * * Inner and outer primary has to come out. *Behind the snap ring
> and washer, there is a seal. *It needs to be replaced. *While you're
> you can get to it). *
> * * * * Put tape over the shifter shaft before putting in a new seal,
> again.
> Phil
> AH#61 *Wolf#14 *BS#89 *bus#1 *CCB#1 *SENS *KOTC#4 * * *ph...@total.nethttp://ah61.comhttp://philb.caEKIII rides with me. *http://eddiekieger.com
> WWJD? *JWRTFM.
> hackerkey://v4sw5CU$hw7ln4pr7ck4ma9u7LMw2m7l7Si982Ct4b8en6a3Xs 7r2p-5.38/-8.*77g4
Thanks Phil. I owe you a drink!! Looks like I have my work cut out
for me......Rich
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
What shaft? Rick UK Motorcycles 26 11-22-2006 09:45 AM
Bent shift shaft - XR100 Darin Motorbike Technical Discussion 2 11-29-2003 03:50 AM
1 2 3 4 5 6 7 8 9
