On May 15, 8:58*pm, mark <mjpe...@gmail.com> wrote:
> Just done a fork oil change amd clean out (forks out) on a 2000
> Blackbird with non standard springs and I have been told by the
> supplier that the air gap should have been measured with the springs
> in. I did mine with springs out as per manual for standard bike. This
> would result in too much oil I think?
Yep.
> Any idea what cc's should be
> removed to get it where it should be?
No, & nobody else will know either.
> Would too much oil (ie leave it as it is) result in overdamping?
No, it will result in less initial 'soft' compression. The air gap
above the oil is basically a spring, which handles the initial
compression before the metal springs take over. More oil equals less
air-spring equals stiffer initial stroke.
If there's far too much oil in there, it will stop the forks
compressing fully, which probably isn't a good thing. I'd recommend
doing the cable tie thing with the damping backed right off (assuming
it's adjustable) & a few hard front brake applications. If the whole
stroke isn't being used, & especially if it feels like it's bottoming
out without fully compressing, I'd syringe[1] some oil out before
taking it for a blat.
Either way, you know what you've ultimately got to do...
[1] Ask your local friendly vet if you haven't got one.
