On Mar 16, 3:47*pm, Matt Johnson <mouche.librem...@gmail.com> wrote:
> checked it out and gas is leaking from all four drain tubes. i turned
> the drain screws all the way around the opposite direction, but that
> didnt change anything.
The float bowl drain screws are not a two-position affair, you have to
tighten them all the way to stop gasoline from leaking out the four
drain tubes.
The float bowl drain screws just have a cone shape on the end which
stops gasoline from leaking out when you tighten them all the way
clockwise.
But there is a little rubber o-ring on each screw which may have
perished from age, they are at least 29 years old, yannow.
The o-rings are part of a gasket set that you probably don't want to
buy at the price. You can get new o-rings for a few cents each at a
good hardware store.
http://www.bikebandit.com/assets/sch.../H00840036.gif
1: GASKET SET 216212-001 $39.56
13,14,18,19 TUBE, FUEL are the float bowl drain tubes
The float bowl drain screws come with the float bowl. If the conical
ends of the
float bowl drain screws are all pitted and corroded, you can chuck the
screw in an electric drill and hold the conical end against a piece of
sandpaper or a whetstone, turn on the drill and manufacture a new
conical end the isn't pitted.
If the floats are stuck, gasoline will come up through the float bowl
air vents.
Most carbs I've worked on have an air vent for each float bowl or, in
the case of four cylinder engines, one float bowl vent between each
pair of carbs.
Your carburetors only seem to have one float bowl air vent though:
http://www.bikebandit.com/assets/sch.../H00840034.gif
19: TUBE 224256-001 $6.04
