Thanks for the posts guy... I am trying hard to change positively... I've
nearly snapped the lever off sometimes, and still it hit neutral... (sigh).
This is my first cruiser, and the one I test rode (for a week) never did
it... my previous Yams never did it either....
>> > It's not a problem with the bike, probably a problem with the way you
>> > change gears. You're probably not applying enough pressure to the
>> > shifter when you change gear. You have to shift it all the way past
>> > neutral. Try consciously giving it a really big kick, and not rushing
>> > it too much, which you tend to do when you're giving it stick.
>> That said, most (all?) bikes have some accidental-neutral-prevention
>> feature don't they? Or is there something wrong with my XR400, that is
>> very hard to get into neutral when it is running?
>> | ^Nothing is foolproof to a sufficiently talented fool^ |
>> | Heath Raftery, HRSoftWorks _\|/_ |
>> *______________________________________m_('.')_m__ _______*
> I'm with Nev, I don't think there's such a jigger. Might try
> adjusting your clutch, it could be binding slightly which makes them
> virtually impossible to get into neutral while running.
