On Fri, 8 Apr 2011 07:18:45 +0100,
(E-Mail Removed) (The
Older Gentleman) wrote:
>One cylinder does look rather low, and one looks worryingly low, but it
>should start anyway.
>Your problem is stale fuel in the carbs; jellied fuel that's blocking
>key passageways and jets.
That explains what is essentially no compression in one cylinder? That
is an issue that needs to be addressed, don't you think? BTW, if you
had actually read the initial post, he said the bike sat for about a
month - that's all. Stale fuel? That's an interesting theory.
>Look, get SWK to strip down the carbs properly. Best solution is
>ultrasonic cleaning, but proper professional-style cleaning plus
>cleaning out all the jets with tiny strands of copper wire and lots of
>compressed air will, if you're patient, do the job.
Right, that should get the compression back up.
As they say, when the only tool you have is a hammer, every problem
looks like a nail. I guess when you have some special carb cleaning
aptitude, that's where the diagnosis always leads.
