Motorbike Forums
Reply
Thread Tools Display Modes
Help with VFR800 starter valve sync
Aram Schiffman
Guest
Posts: n/a
      08-24-2008, 09:23 PM
Hi All,
I used to come here a lot, then kind of drifted off. Naturally I come
back when I need something (roll eyes at self). Hope this is ok.
Confusing maintenance issue. I'm syncing the starter valves on my '99
Honda VFR800. I've done this before with no issue. This time, I have
two problems, or maybe they're really one problem. First, #3 vacuum is
really low (<150mm). I swapped hoses around to make sure it wasn't a
leak in my setup; it's not. Anyway, second thing, I turn the little
adjust screws -- and nothing happens. Vacuum levels are dead stable.
I don't know if this is one question or two. If my #3 has a vacuum
leak, where are the likely sources? What would cause the adjust screws
to have no effect whatsoever?
Thanks, and ride safe.
Aram
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
VFR800-v-tec? CrazyCam Australian Motorcycles 68 07-31-2006 03:36 AM
VFR800 2001 Big_Harold Australian Motorcycles 32 01-17-2005 05:42 AM
WTB - VFR800 bits Justin Australian Motorcycles 1 09-08-2003 08:30 AM
[Melb] FS: Honda VFR800 Tony tony@remove_to_email_pobox.com Australian Motorcycles 7 08-12-2003 09:48 AM
1 2 3 4 5 6 7 8 9
