Motorbike Forums
Reply
Thread Tools Display Modes
Honda Shadow VT1100c 1996 clutch problem
beachball
Guest
Posts: n/a
      08-19-2009, 11:45 AM
Hi,
When pulling the clutch lever the clutch do not release in full. Also
bike do not start when in gear and clutch is pulled, will only start
when in neutral. Clutch plates recently replaced and still in good
condition. Is there anybody that can give me some pointers in finding
the problem and solving it.
Thanks
little man upon the stair
Guest
Posts: n/a
      08-19-2009, 02:57 PM
> when in neutral.
First, make sure there's enough fluid in the clutch master cylinder.
If that's OK, you may have to bleed air out of the clutch slave
cylinder.
I have found that opening and closing the bleeder screw doesn't work
very well, so I unbolt the clutch slave cylinder and use a phillips
screwdriver to
gently push the piston back as far as it will go.
I let the slave cylinder hang down on the hose so any air bubbles will
go back up the clutch hose to the master cylinder.
Then I can bolt the slave cylinder back onto the engine and pump up
hydraulic pressure until the clutch releases fully.
Some people use a Mighty-Vac to suck air out of the clutch fluid
system by attaching it to the bleeder screw. Problem is, the Mighty-
Vac will also suck *air* past the threads of the bleeder screw when
it's loosened.
Hank
Guest
Posts: n/a
      08-19-2009, 05:45 PM
BUY A MANUAL
"beachball" <(E-Mail Removed)> wrote in message
news:08d33a70-1abd-42e0-ba16-(E-Mail Removed)...
> Hi,
> Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1986 Honda Shadow VT1100C Hofner Motorbike Technical Discussion 1 03-20-2006 11:39 PM
WTB: Honda Shadow VT1100C 1986 Engine ShadowHawk Texas Bikers 0 08-21-2005 08:13 PM
FS: 2001 Honda Shadow Spirit VT1100C Eli Vela Texas Bikers 0 12-05-2003 02:08 AM
1 2 3 4 5 6 7 8 9
