WOW...thanks for the great info.
In article <(E-Mail Removed) .com>, skimmer
says...
>checkers wrote:
>>I have an 85 Shadow. Is it normal for the rear wheel to be very hot to the touch
>> after riding about an hour? What would cause this to happen?
>The rear wheel and tire will always have some temperature rise because
>you are transmitting power to the ground through the rubber and the
>wheel and tire will also get warm because of the heat of the engine and
>the fact that the engine blocks airflow.
>The tire also gets hot because it flexes as you go over bumps. If the
>air pressure is low, the tire will flex more and get hotter.
>I have also noticed that if you have a rear disk brake, it will usually
>be hotter than the front disk brake. I speculate that a rear disk tends
>to drag more because of the more rigid mounting of the caliper, plus
>dirt and worn out material from the brake pads seems to accumulate next
>to the caliper pistons.
>I suspect that the front brakes don't get as hot because the forks flex
>a little as they try to correct for the motorcycle alternately falling
>to the right and to the left as it travels down the road. The forks
>stabilize the motorcycle by providing alternate thrusts
>on the side the motorcycle is falling toward.
>This thrusting action may be just enough to keep the front brake pads
>knocked back a few thousandths of an inch.
>Now, if you're talking about the rear brake disk getting so hot that
>water sizzles on it like on a hot frying pan, you can figure that the
>brake pads are really dragging. This can be caused by air in the fluid
>system expanding and pushing the pads against the disk.
>If you have a drum brake, it might be out of adjustment.
