Cobra wrote:
> 1989 Kama 600 Ninja oil light has been on since an oil change several
> thousand miles back.- Does anyone know how to make it go off now?
Pull the wire off the switch. If the light goes out, the switch may be
the problem, or the oil passage to the switch to the switch may be
plugged up.
If the light stays on with the wire pulled off if it, you have a wiring
problem somewhere.
Unscrew the switch and put a rag over the hole to catch any oil that
comes out the hole when you crank the engine with the starter.
As I recall, a Kawasaki will crank with the kill switch in the off
position, but, it doesn't matter if that's not true. If the engine
starts, shut it off imediately so the oil doesn't squirt all over the
place.
Squirt some aerosol carburetor cleaner into the hole in the switch.
Turn it upside down to drain the carburetor cleaner out.
Then, carefully screw the pressure switch back into the hole, hook up
the wire and start the engine and see if the light goes out. If it
doesn't, the switch is probably bad.
You can use an ohmmeter to check the contacts of the switch. You should
get a very low reading from the body of the switch to the terminal.
Applying oil pressure to the oil port should make the contacts open,
giving you a very high reading of 500K ohms or more.
