Motorbike Forums
Reply
Thread Tools Display Modes
A problem for your jollification.
steve auvache
Guest
Posts: n/a
      04-12-2007, 01:24 PM
I have been fettling the GS in an attempt to improve the running[1]
since I put the K&N filter on and have a little issue with the engine
not slowing down very quickly when I close the throttle. I am fairly
confident it is probably running a bit lean but could this be the cause
of it? If not then what, the sliders seem free enough.
[1 ]Finding out one of the coils was a bit iffy certainly helped the
poor starting issues.
steve auvache
Simon Wilson
Guest
Posts: n/a
      04-12-2007, 01:41 PM
If the slides are free then it's definitely mixture - lean running
usually causes the revs to rise (eg if you leave it on tickover with the
fuel tap switched off, if fitted, the revs will rise before it conks out.)
/Simon
Eiron
Guest
Posts: n/a
      04-12-2007, 01:49 PM
Isn't that the sign of an over-rich mixture?
Eiron.
steve auvache
Guest
Posts: n/a
      04-12-2007, 02:01 PM
In article <evlcua$tce$(E-Mail Removed)>, Simon Wilson
<(E-Mail Removed)> writes
Which is almost certainly not standard. That much I am sure of.
The LHS particularly had been well ****ed about with before I got the
bike and most of what I have done since has been putting it right rather
than trying to improve performance.
The only thing I am not too sure about is the head on the fuel supply
and how much difference it would make. My temporary rig is gaffer taped
to the bars and so is a foot or so higher than with a tank on, which
would tend to make it rich.
I just want to make sure it is as right as I can get it before I commit
to putting the tank back on. It is far too much faffing around to be
taking that on and off a dozen more times for bugger all improvement.
> - lean running
And air cooled engines don't like running for too long while you play
either so it is short bursts of annoying the neighbours and many tea
breaks, which don't help. Colostomy bags don't come cheap.
steve auvache
steve auvache
Guest
Posts: n/a
      04-12-2007, 02:03 PM
In article <(E-Mail Removed)>, Champ
>On Thu, 12 Apr 2007 14:24:40 +0100, steve auvache
>Check that the diapragms are not damaged.
One was but has been retired. The three I have left are all fine as far
as I can see.
steve auvache
Cane
Guest
Posts: n/a
      04-12-2007, 02:06 PM
The throttle cable is sticking.
steve auvache
Guest
Posts: n/a
      04-12-2007, 02:27 PM
In article <(E-Mail Removed) .com>, Cane
I don't think so but it is only single cable operation so I cannot be
sure. It is just like a sticky slider but it ain't that, which is why I
am asking if extreme mixture could be the issue.
steve auvache
Rich B
Guest
Posts: n/a
      04-12-2007, 02:32 PM
>> the fuel tap switched off, if fitted, the revs will rise before it
>> conks out.)
No.
Rich B
Bandit 1200S
Take out the obvious to email me.
Rich B
Guest
Posts: n/a
      04-12-2007, 02:36 PM
> taped to the bars and so is a foot or so higher than with a tank on,
> which would tend to make it rich.
If your float valves are working OK, it shouldn't make any difference (for
all reasonable values of head of fluid). Until the fluid pressure is enough
to overcome the float valves, the float level will be unaffected. It's not
a linear thing.
Rich B
Bandit 1200S
Ace
Guest
Posts: n/a
      04-12-2007, 02:38 PM
On Thu, 12 Apr 2007 15:37:40 +0100, Champ <(E-Mail Removed)> wrote:
>On Thu, 12 Apr 2007 15:03:38 +0100, steve auvache
>>as I can see.
>Three? On a twin?
>You're trying to be amusing, aren't you?
Or he has a spare pair of carbs?
_______
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
non-op problem ken ward Bay Area Bikers 3 08-30-2004 12:52 AM
1 2 3 4 5 6 7 8 9
