On Sep 1, 5:37*pm, netsurfer802 <pdntspad...@gmail.com> wrote:
> Hi:
> I'm kind of new to fixing motor scooters...I'm trying to read up on a
> Geely moped --I believe a four stroke--that's having a hard time
> starting and when reading the manuel came across some questions.
> This is what it says in the manuel:
> Hard/No Starting
> Fuel supply system:
> - Check fuel supply for water.
> - Check petcock for blockage.*
> - Check for air-intake leakage.
> - Check for excessive fuel in cylinder: remove spark plug to
> discharge.
> - Check air filter for blockage: clean element.
> My questions are:
> How do you check the fuel supply for water?
> How do you check the petcock for a blockage?
> How do you check for an air-intake leakage?
> How do you check the cylinder?
> What tools do you need to do all this?
> Thanks in advanced for any helpful answers that a novice could
> understand.
You might want to start by buying a set of metric
socket wrenches that includes a spark plug wrench.
A pair of pliers, a set of open/box end metric wrenches,
a couple of Philips head and flat bladed screw drivers
and some sort of manual (manuel is hard to find) like
Haynes covering elementary motorcycle maintenance.
