Hustlin' Hank wrote:
> I have an 86 (I think) Honda XR250. The only way I can get it started
> is to put gas directly into the carb. I cleaned the carb and EVERY jet
> is open. Even the pilot jet that I put a small wire thru. Once started,
> it runs fine. So, I am thinking compression.
> I haevn't adjusted the valves and the auto-compression release yet. If
> someone knows the tappet settings and how to adjust the compression
> release, i would appreciate it.
> Any other comments are greatly appreciated as I don't have a manual
> for this bike.
> Also, I am in central Ohio and will sell this bike "as is" for $450.
> There is no title, but I will supply you with a notorized bill of sale.
Is the float bowl full or empty ? Seems a little early, but maybe
a vacuum operated fuel petcock ? Does it act the same way
on reserve ?
Does it act the same way warm as it does cold ? If it starts OK
warm, could be a choke problem.
When you try to start it and it won't start, are the plugs wet or
dry ?
Seems unlikely that it's compression if it runs OK after starting.
