On Jul 16, 9:41*pm, Rob Kleinschmidt <Rkleinsch1216...@aol.com> wrote:
> On Jul 15, 5:05 pm, Will <will.gil...@tiscali.co.uk> wrote:
> > Hi all,
> > When I try to start, neutral light green, kill switch off, sidestand
> > up, clutch in, and press the start switch all I get is clicking
> > (repeatedly when I hold the starter switch on). The battery is fully
> > charged and checked. The bike was standing for a couple of months, no
> > problems previously. The clicking would imply that the relay is ok and
> > i checked the starter motor seperately and its ok so im guessing there
> > is a problem with the solenoid but would like some advice if anyone
> > else has had similar problems.
> > I will try shorting the solenoid but if the starter is working when
> > connected directly whats the point? Could the relay be faulty even
> > though its clicking? and how can i check each point along the system
> > to isolate the problem? I have a hayes manual to help me but electrics
> > aren't my strength!
> > Thanks
> You might try a jump from an auto battery.
> If it starts, then you have a bad battery.
> (This assumes that the motorcycle battery
> is pretty well charged first).
> You might also take a look at both ends of
> the battery cables to make sure they're really
> clean and tightly connected.
Thanks all and yes it was a duff battery but all's well that ends
well, Thanks for all your help and advice, as I said electrics are not
my strong point !
