0 weight oil ?
Discussion in 'Australian Motorcycles' started by pnin, Oct 4, 2008.
  1. pnin
    pnin Guest
    noticed some hi tech synthetic oils now rated as 0/50.
    would 0 be like water ? Anyone used these in bikes ?
    Pnin.
    pnin, Oct 4, 2008
  2. pnin
    Nev.. Guest
    They can invent as many different multigrades as they like. The oil
    lubes the engine, it's not a fad. Use the ones that the manufacturer
    recommends. With my limited knowledge of oils I'd say a 0 weight oil
    would be ideal for running in your motorbike during winter in Antarctica.
    Nev..
    '07 XB12X
    Nev.., Oct 5, 2008
  3. pnin
    pnin Guest
    wot are the roads like down there ?
    Pnin
    pnin, Oct 5, 2008
  4. White..
    George W Frost, Oct 5, 2008
  5. pnin
    Certainly can! ;-)
    BTH!
    BT Humble, Oct 6, 2008
  6. pnin
    Nev.. Guest
    Yes they recommend that for Australian conditions where ambient starting
    temperatures are between 5C and 50C you probably need a 20W-50 and if
    you're anywhere where a 0W rating is required for cold weather starting
    good luck because you'll probably be turning the engine by hand. :)
    Nev..
    '07 XB12X
    Nev.., Oct 6, 2008
  7. pnin
    Assumedly it just hovers in your crankcase.
    Knobdoodle, Oct 8, 2008
