1 up 5 down!
Discussion in 'UK Motorcycles' started by Cryasor, Jul 23, 2006.
  1. None from me. My ShiteOldGSs used to have working gear indicators but
    when they broke it wasn't something I felt inclined to fix. I'd
    occasionally find the facility useful when in top and a glance at the GI
    would confirm I didn't have another gear to go up. Otoh, when they broke
    I would occasionally cruise along at umpteen revs in 4th, thinking I was
    in top.
    So there ya go. Swines and roustabouts.
    Grimly Curmudgeon, Jul 23, 2006
  2. Cryasor
    Timberwoof Guest
    My R1100GS has a gear indicator, too, but I don't use it much.
    Timberwoof, Jul 23, 2006
  3. Cryasor
    Timberwoof Guest
    The difference is that if N is at the bottom, you'd often or always end
    up shifting into N, and then you'd *have* to shift back up into 1.
    If N is in between 2 and 1, you can skip N on the way down, and be in
    1st during the stop. And that's useful for when some idiot cager behind
    you wants to do a SMIDSY and stop at the line instead of behind you.
  4. Matchless (1957 G3LS at least) gearboxes were 1 up 2 (or was it 3?) down.
    <drifts off into incoherent reminiscences of felt oil filters and exploding
    big ends>
    Martin Coogan, Jul 23, 2006
  5. Cryasor
    Timberwoof Guest
    Well, you can argue the point with me if you want to; the OP asked why
    the gears are set up this way; I gave some plausible explanations and
    showed how they fit in with how I ride (or, more likely, how my style of
    riding fits in with how the gears are set up). I guess you're stuck with
    counting gears even though you don't have to...
  6. Cryasor
    Mike Young Guest
    It's an important skill, probably under-developed in most riders because
    there are few dire consequences from mis-counting. OTOH, most corners in
    street riding are taken in 2nd gear. I like to be in 2nd as I have grown
    accustomed its cues on road speed. (2nd gear on my bike is usable between 15
    and 85 mph. That about covers the range of speeds I'm interested in. Your
    second gear might differ.) Aside from that, keeping count means you can stop
    shifting into the non-existent 7th.
    Mike Young, Jul 24, 2006
  7. Cryasor
    Bear says...
    Half urban myth, half truth.
    The RD250 and RD350A had a 6 speed box with the usual '1 down 5 up'
    gearbox but 6th was, for some fucking obscure reason known only to some
    slanty eyed engineer, blanked off and as such unuseable. Motorcycle
    Mechanics - as it was then, it eventually became Performance Bikes - got
    their resident 'expert' involved and he explained how to liberate the
    missing 6th gear. What he didn't explain was how to put a stop on the
    selector drum to ensure you couldn't engage 1st gear directly from 6th.
    We've all done it, been flat out in 6th and looking for the next gear
    up.
    Cue lots of very damaged RD250 and RD350As, and not an inconsiderable
    number of broken young lads.
    To be fair to MM, they did print an apology and a supplement explaining
    the correct method of stopping the selector drum from going full circle
    in the next month's issue.
    Yamaha decided the RD250 and RD350B should have all 6 gears available.
    Lozzo, Jul 24, 2006
  8. Cryasor
    Cryasor says...
    My FS1E had all 4 gears down with neutral at the top. When I bought my
    RD250E it took me all of 5 minutes to get used to the box being
    different, but there's no way I could ever get on with British style
    right foot gearchanges.
    Lozzo, Jul 24, 2006
  9. Cryasor
    Cam Penner Guest
    And you've never missed a shift, or miscounted ever?
    Shifting down and expecting power to be there from 1 to N
    would happen at the WORST possible times. Personally, I'd
    like to see N locked out unless the wheels are not turning.
    THEN I wouldn't care if it were at the bottom or between
    first and second.
    I don't usually use N. My RZ needed the phases of moon to
    be in alignment to find it.
    Cam Penner, Jul 24, 2006
  10. Cryasor
    BGN Guest
    It keeps the mind active.
    BGN, Jul 24, 2006
  11. Cryasor
    deadmail Guest
    Cam Penner <>
    Well, of course I have. But not that often.
    That's a reason that makes sense.
    deadmail, Jul 24, 2006
  12. Cryasor
    snip>
    I knew it could be done but didn't know anyone who'd tried it.
    I'd still argue against the fact that Yamaha made a 2 stroke with a
    suicide box. They didn't - mechanical **** wits made them suicide
    boxes.
    Andy Bonwick, Jul 24, 2006
  13. Cryasor
    Cam Penner Guest
    Two things I do compulsively on a bike. Shift and cancel
    my turnsignals. I always shift down to first AS I slow.
    Again, once stopped. If I'm at a light for more than 20
    seconds, I'll shift down into first again. I also shift
    into first just before taking off from any stop too. That
    little green Neutral light on my guages is in pretty much
    factory fresh condition.
  14. I started to post the same reply, and then realised that that wasn't
    what the OP asked; the mandate was for left gearchange, right brake. I'm
    not sure if it mandated the gearchange direction, but that was minor
    compared to standardising gears/brake.
    Dr Ivan D. Reid, Jul 24, 2006
  15. Turby wrote
    Well it would be nice if they did but so far all the ones I have
    devoured have been illiterate.
    And just for the record the Califnian Medjool Dates that you lot are
    probably so proud of are not a patch on the Israeli ones which, in turn,
    are downright insipid when compared to Jordanian an Iranian offerings.
    Not that Medjool dates are actually that wonderful either, just big.
    steve auvache, Jul 24, 2006
  16. Cryasor
    lubecki Guest
    Well, putting neutral somewhere next to 1st makes sense, because you're
    in neutral only when you're stopped, and to start moving from a stop
    you need to get into 1st gear. Putting 1st BELOW neutral also makes
    sense, because then all it takes to get moving from neutral is a quick
    push down on the shift lever (much easier than pushing up on the lever
    that would be required if neutral was all the way down on the bottom).
    The rest of the pattern follows from this basis (1st right above
    neutral).
    I suppose another shift pattern that fits would be neutral on top, then
    down to 1st, then down to all the other gears. But the current pattern
    was probably chosen to make it intuitive: "push up to go up a gear".
    -Gniewko
    lubecki, Jul 24, 2006
  17. Cryasor
    lubecki Guest
    I wonder why racers use the upside-down pattern instead of simply
    adding a heel rocker. That would easily solve the problem of upshifting
    in turns - push down with your heel to upshift.
    -Gniewko
  18. Probably to avoid accidental changes mid-corner as they move around on
    the bike.
    Grimly Curmudgeon, Jul 24, 2006
  19. Turby wrote
    Well yes, force of circumstance and all that old tosh.
    Israeli Oranges, traditionally large, not terribly juicy or particularly
    sweet but easy to peel orange coloured fruit, marketed as Jaffa Oranges
    over here, are absolute shite. What we are seeing now though are
    smaller things from the same family but so tasty it is untrue, South
    African Mandarins are to die for.
  20. But that's not why they put it there; They put it there so that
    neutral would be BETWEEN TWO GEARS. Why? Because neutral is not a
    stop. If you always push the lever until it stops, then you'll
    always end up in gear -- never in neutral. This is considered a
    Good Thing, especially by those riders who NEVER shift into neutral
    at stops.
    -- Foo!
    Foobar T. Clown, Jul 24, 2006
