125RS
Discussion in 'UK Motorcycles' started by richard.ingall, Aug 22, 2005.
  1. crank rebuilt by local Honda dealer
    nothing left over
    top-end not removed this time (has been apart b4 and completely renewed)
    No seperate small-end, the piston pin runs direct in the rod, which is brand
    new
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, richard.ingall
    If you handle a spanner as well as you handle a newsreader, it's fucked.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Aug 22, 2005
  3. richard.ingall
    So you didn't do any of the work yourself? Why does this feel so much
    like getting blood out of a stone?
    Also, you seem not to be able to post properly.
    Muck, Aug 22, 2005
  4. richard.ingall wrote
    and your point is?
    steve auvache, Aug 22, 2005
  5. richard.ingall
    You can't replace a needle roller bearing that isn't there.
    Muck, Aug 22, 2005
  6. Muck wrote
    Good point. How though did you extrapolate that from the above posting?
  7. richard.ingall
    The bit about the pin running direct in the rod.
    Muck, Aug 22, 2005
  8. Muck wrote
    Kinnel. You did better than I did then.
  9. richard.ingall
    <shrug>
    Well... a bit.
    Muck, Aug 22, 2005
Similar Threads
Loading...
