1500GL aftermarket U/L Rad Hoses #'s needed
Discussion in 'Motorcycle Technical Discussion' started by Mystro, Jun 6, 2005.
  1. Mystro
    Mystro Guest
    I need the manufacturer and parts number for upper and lowers hoses for
    both radiators on my ol'88 GL1500 with 76k mileage.I'm just about to
    change the Timing belts so I thought since I was so close down
    there..why not change the hoses? Any advise will be very much
    appreciated.
    Mystro, Jun 6, 2005
  2. Mystro
    Bownse Guest
    Can't tell you the exact type but I took my old hoses in once and looked
    at auto hoses until I found the ones that would work. They have the
    right bends but had to be cut on either end to get the section I could
    use. No criss-cross on such things, so it's all manual labor and the
    patience of the parts guys at NAPA.
    The next time, I just got the right hoses from Honda and was done with
    the whole swap in less time than I spend trying to find the right hoses
    elsewhere.
    Bownse, Jun 6, 2005
  3. Mystro
    Mystro Guest
    Thanks for your suggestions,I was hoping for actual cross numbers for
    gates,napa or some other hose company mainly because of my distant
    location from a larger town to use your method but it may be best in the
    long run to pay the full Honda price as suggested if I can't locate part
    numbers.
    Mystro, Jun 6, 2005
  4. Mystro
    mystro Guest
    Ouch! just checked Honda Parts online source and the upper and lower
    hose will be $100!
    mystro, Jun 7, 2005
  5. Mystro
    Bownse Guest
    amortized over the life of the hoses, it's very reasonable. even
    accelerated amortization at $10 per year per hose (5 years) it's nothing
    compared to the average cost of owning and properly maintaining a bike.
    You'll spend more than that on oil if you ride the bike any.
    Bownse, Jun 7, 2005
  6. Mystro
    mystro Guest
    Thanks for the link Mark but I was not able to navigate to the GL1500
    parts for some reason
    mystro, Jun 9, 2005
  7. Mystro
    Mystro Guest
    I'm still trying to find upper and lower hoses for a 88
    GL1500..servicehonda either doesn't carry 1500 hoses or I'm lost. :(
    BTW,anotrher owner says you rarely ever have to replace these hoses but
    I'm alittle suspect of that thinking..am I wrong?
    Mystro, Jul 10, 2005
  8. Mystro
    Bownse Guest
    if you're willing to spend the time, you can take the oem ones to a good
    auto parts place and compare them to their inventory. you'll eventually
    find hoses that have the right bend if you cut one (or the other) ends
    off the longer auto hoses.
    service honda had the right stuff. some of these places are poorly
    designed and don't work well with HTML-compliant browsers. try using
    Internet Exploder to see if that will work.
    Bownse, Jul 10, 2005
    Chris Hornberger, Jul 11, 2005
  10. Mystro
    Mystro Guest
    Thanks guys,if anyone has the time to locate the exact link to the
    GL1500 upper and lower hoses maybe I can get there that way?
    Mystro, Jul 11, 2005
  11. Mystro
    Mystro Guest
    Thanks Mark,looks like an active X issue that I'll fix..thanks all
    Mystro, Jul 16, 2005
