16 inch front wheel?
Discussion in 'Australian Motorcycles' started by Farticus, Dec 30, 2005.
  1. Farticus
    Farticus Guest
    Hello all,
    After many years I am fortunate to again be riding on two wheels.
    The last time I rode bikes was back in 1966. Up until then I owned and rode
    a Norton Dominator 99 (600cc) and Triumph Tiger 110 (650cc) plus a variety
    of Italian 175 to 250 cc machines.
    I recently obtained my open bike licence (Queensland) and looked around for
    something affordable and small enough to get back into motorcycling.
    I found an immaculate 1989 Kawasaki GPZ500S with (believe it or not!) only
    28000 Km on the clock. Everything very original, and everything works like a
    dream.
    My concern is that after reading up reports on the internet, it seams like
    these bikes have a problem where the front will suddenly loose it and slip
    out on a bend resulting in serious tarmac burns for the rider. This they say
    is due to the 16 inch wheels (especially front).
    So far I have had no problem, the bike handles well and is extrememly
    flickable on corners. The present front tyre fitted is a Michelin.
    Does anyone have an opinion/experience/suggestions that would lead me to
    feel more comfortable on this bike, instead of almost crapping myself
    whenever I go into a bend, waiting for the front to slip away!!
    Why don't scooters have this problem with their small wheels (or do they?).
    I really like the bike and would like to keep it for at least another year
    before upgrading to something newer and bigger.
    Cheers.
  2. Farticus
    J5 Guest
    welcome back, seems things have changed just a touch hey
    not a bad choice
    prob due mostly to riding it at 11/10ths like an R1
    it must be true , i read it on the internet
    see you ride it properly , if the tyres are old i would be changing them
    anyway
    make sure there is air in the tyres and dont ride like a knob
    you ride within it limits unlike journos
    and it will do you well
    J5, Dec 30, 2005
  3. Farticus
    HEY!!
    Knobdoodle, Dec 30, 2005
  4. | Hello all,
    rode
    for
    a
    | dream.
    say
    they?).
    | Cheers.
    Hi Farticus,
    As JohnnyFive said, keep it sane and you will be ok. I owned one back in
    1992 when I returned to riding after a 15 year break, and found it to be a
    good handler with a really torquey motor.
    A common reason for loosing the front end on some bikes (e.g. the older
    SV650 Suzuki) is that the front springs are too soft to push like Mick
    Doonan down hill into a corner under brakes.
    The springs bottom out, and when the tyre momentily looses contact with the
    road (hitting a bump), the tyre is pushed past the point of friction....
    front end lose.
    New (stiffer) springs at the front may be good idea may be good insurance,
    as 1989 was a while ago.
    Depends on your weight too (Kawasaki Handbooks say 68 Kg is the set up
    reference weight).
    16" wheels were all the rage in the 1980's to make a "poor" chassis turn
    faster in corners, than the larger sizes (18") could.
    The compromise is now the common 17".
    Rob.
    Getting Slower & Slower !, Dec 30, 2005
  5. So far I have had no problem, the bike handles well and is extrememly flickable on corners.
    Then there should really be no problems. Johnny5 has it right, mopst
    with issues are probably out of their league trying to go to hard and
    beat R1's..
    Just take it easy and if you have no problems with it, **** what you
    read on the internet :)
    Biggus La Great., Dec 30, 2005
  6. Farticus
    ysidro Guest
    My VF1000R has a 16inch front wheel :-(
    Y.
    ysidro, Dec 30, 2005
  7. Farticus
    CrazyCam Guest
    Good i'n't it? :)
    You might have noticed a bit of a change, then.
    Sounds good so far....
    "They say"...."internet".... oh well, it _must_ be true! :-|
    I had the GPZ750 Turbo, with the 16" front wheel. 1987, I think.
    The only problem I had with that bike was a head shake, and the cure was
    to use "old fashioned" tyres with grooves going all the way round the
    circumference of the tyre. The more modern style of (apparently) random
    angled grooves in what otherwise looks like a slick tyre.
    I can't actually remember the numbers, but it was a Michelin tyre that
    "worked" properly on the Turbo.
    There is nothing inherently wrong with 16". As a front tyre size, it has
    come in and out of fashion several times, and I still have a bike with
    that size front, a Honda Hornet...which also preferes a groove all the
    way round the tyre, like he Bridgestone 012.
    Your bike might well benefit from fresh fluid in the forklegs, perhaps a
    wee bit thicker than original standard.
    Perhaps, too, the tyres are "aged in the shed" and fresh rubber could be
    applied...but don't try for too modern sporty rubber.
    Well, my Honda with 8" wheels goes round corners just fine.
    It _really_ turns in fast!
    Relax, ride the bike, enjoy....remember that it isn't a state of the art
    race bike.
    Just a stab in the dark, but, the 'orror stories of front ends sliding
    out, did they come from septics?
    I have a vague feeling that there used to be a class of bike racing in
    the us based on GPZ500S's, basically for beginner racers, and I could
    see how they'd have had problems..... apart from being septics. ;-)
    regards,
    CrazyCam
    CrazyCam, Dec 30, 2005
  8. Yup 500s were big with scum Yanks
    VF500's were huge in the racing scene, you should see the threads on
    Perkins VFR list back in 97 on these things and the $ people spent on
    them,.
    Biggus La Great., Dec 31, 2005
  9. my VF750, GPX750, GSX1100, and others have had 16in front wheel
    First fireblades had 16's..
  10. Farticus
    J5 Guest
    and later ones 929 was the 1st to go 17 in about 99/00
    J5, Dec 31, 2005
  11. yer wasnt sure when they changed.
    So 'modern' style tires would still be available.
    always wonder what "GOOD" tires are available in the old smaller sizes
    for older bikes like the VF750 with the 120 x16 front and 130/ 140 x
    18 rear....
  12. Farticus
    FruitLoop Guest
    Was it a TF 11 , I had one on my FJ1100 about 1985-86 , it was a very good
    tyre at that time
    FruitLoop, Dec 31, 2005
  13. Farticus
    Bummers Guest
    GPZ750/1100s used to have "loose the front end" problems in Proddie
    racing in Australia. I remember Lennie Willing going down the road a few
    times with a front end dissappearing from under him. I had the same
    experience at Forest Elbow on my attempt to race an 1100 in '87.
    But they are extreme examples. I doubt if it would be a problem on the road.
    Buimmers
    Bummers, Dec 31, 2005
  14. Farticus
    Hey Bummers; what happened to Len Willing?
    He seemed to be hale and hearty and then suddenly he was dead.
    Any info?
    Knobdoodle, Dec 31, 2005
  15. Farticus
    Bummers Guest
    I think there was a rumour of substance abuse & another of being bashed
    in a bar in Hawaii on his way back from the States & getting a clot.
    Both unsubstantiated.
    But he liked his substances.
    Whatever - another good bloke gone to the racetrack in the sky!
    B.
  16. Farticus
    Ta muchly.
    (I hadn't heard either of them)
  17. Biggus La Great., Dec 31, 2005
  18. Farticus
    FruitLoop Guest
    Ahhh Bathurst , what a track , at least you were lucky enough to have a go
    there , I never was fortunate .
    GREAT TRACK , you needed balls . How was mcphillamy at full noise ?
    Met Andrew Johnson pissed a few times at PI though . He was kind enough to
    give me a HRC jacket for free .
    Also the RZ500 a 1984 or 5 winner I think of the 6 hour also had the
    dreaded 16 incher as well
    Was piloted by Mike Dowson and was it Kevin Magee
    My memory is fading
  19. Farticus
    gearsau Guest
    Yes, the RZ500 was ridden by Mike Dowson and Richard Scott. Just beat
    another 16 " front wheel bike ridden by Wayne Gardner and John Pace.(
    VF1000R)
    Rgds........Peter
    gearsau, Dec 31, 2005
  20. Farticus
    gearsau Guest
    Well, I never knew that W.G was riding Kawasakis as well !!
    Some-one is having us on here .W.G was riding around Pommie tracks
    in 1984 / 85 on HONDAS
    Rgds............Peter
