1961 R60/2 BMw
Discussion in 'Motorcycle Technical Discussion' started by Hans Kroemer, Jun 9, 2005.
  1. Hans Kroemer
    Hans Kroemer Guest
    Seem to have a blocked gasline to the right carb; how to fix? I have tried
    air to no avail. I donot want to take the hose of the carb connection.Any
    other ideas..
  2. I can understand why you wouldn't want to risk damaging original
    parts---it's probably difficult or impossible to find the original kind
    of fuel hose...
    You could try squirting some aerosol carburetor cleaner down the hose
    and leave it sit for half an hour. Try STP or GumOut or Berryman's
    B-12---but this is at your risk, if the fuel hoses you're talking about
    are 44 years old and are natural rubber covered with fabric. Carb
    cleaner might dissolve natural rubber...
    Anyway, if you do use a aerosol carb cleaner, fill up the fuel line,
    let it sit for half an hour, then open up the fuel drain on the bottom
    of the carburetor float bowl and let the old bad stuff drain out. Then,
    if you spray more carb cleaner down the fuel hose and watch all the
    crud come out the float bowl drain...
    If you get lots of dirt and rust come out the drain plug, you know that
    there's a lot of dirt remaining in the float bowl and you really should
    take the float bowl off and clean it out. If you don't clean it out,
    loose dirt will get sucked up into the carburetor's jets and internal
    passages when you get the engine running...
    That motorbike probably has a Bing slide valve carb or something that
    looks like an Amal...
    Another way to get aerosol carb cleaner down into the float bowl of a
    slide valve carb is to raise the slides all the way up and carefully
    squirt the aerosol down past the needle. But, you'd probably have to
    remove the air intake tube that goes to the air cleaner and you might
    not want to do that, either...
    krusty kritter, Jun 9, 2005
  3. Hans Kroemer
    OH- Guest
    If I don't remember wrong (I had one of those for 11 years)
    the hose goes to the float bowl cap. If that is right, just
    take of the cap and test if you have fuel flow that far. At
    the same time you can lift out the float and check that it
    moves freely, clean the float, inspect the float needle and
    clean out any crud in the float bowl (again, I might be wrong
    but I don't think there is a "normal" float bowl drain).
    But, just being curious here, what is so special about removing
    the hose? As someone else suggested, it might even be time
    to get some new.
    OH-, Jun 9, 2005
  4. If it's a 1961 fuel hose, it's definitely time for a replacement.
    I think you need to find a good shop or mechanic. The bike is
    worth some money as is. Don't crap it up if you don't know what
    you're doing. If it hasn't run in a long time, it really ought
    to get some knowledgeable TLC before you run the engine.
    Rob Kleinschmidt, Jun 9, 2005
