1972 Honda CB350 - Gas tank
Discussion in 'Motorcycle Technical Discussion' started by SaulDH, Apr 27, 2004.
  1. SaulDH
    SaulDH Guest
    For some reason my bike must be refilled on half a tank of gas. It is
    unable to use the lower half. I don't understand because the petcock
    is all the way on the bottom of the tank. If it were clogged then I
    would assume that it wouldn't get any gas even with a full tank. The
    hose that connects both sides of the tank together is working
    properly, and both sides of the tank are being used equally. Does
    anyone have any idea whets wrong?
  2. SaulDH
    Bill Smith Guest
    There are two inlets to your petcock, one higher up in the tank and
    one at the bottom for the reserve. What's most likely is the inlet to
    the reserve portion of your petcock is plugged with debris from the
    tank. Rust is a possibility and other stuff that just builds up over
    the years. Drain your tank and take the petcock out and clean it. Make
    sure both circuits are clean. IIRC that petcock can be easily
    disassembled for just this purpose.
    Bill Smith
    Bill Smith, Apr 27, 2004
  3. SaulDH
    Bill Smith Guest
    LOL!
    Yer a BIG help. What would we do without good samaritans like you. Got
    any interesting political theories?
    Bill Smith
    Bill Smith, Apr 28, 2004
