1973 Honda CB175
Discussion in 'Motorcycle Technical Discussion' started by Tip Harris, Aug 2, 2007.
  1. Tip Harris
    Tip Harris Guest
    Does anyone know the correct routing for the fuel lines? Tank valve has STOP-ON-RES with 2 spogots , one for on & one for res, I presume. Each carb has one inlet. Does one line simple go from each carb to either outlet on the valve? Thanks.
