1974 honda 550 fours
Discussion in 'Motorcycle Technical Discussion' started by Ceric, Jul 23, 2003.
  1. Ceric
    Ceric Guest
    I originally bought this bike from a lady who said she has not used
    this bike in a few years. I took the bike home and ordered an old
    mechanics book for the bike. I then proceeded to dismantle the entire
    carbs right down to the gaskets. My intentions were to replace all the
    parts but when I opened everthing up there was so much rust in this
    thing it was pathetic. The gas tank holy junk yard dreams batman, I
    had to get a tetanus shot just from looking at it. I cleaned out the
    carbs and derusted the tank, then I sealed the tank with a kit I
    bought from napa autostore. I also cleaned out the bowl beneath the
    gas tank (PSI) and the little screen in there. The Bike ran
    beautifully for about a month when I thought it needed an oil job.
    After taking it to Northern Cycles in Michigan the guy pointed out
    that I needed new tires and the works on this bike. After sinking 350
    bucks to get this bike up to par I decided I would take on the task of
    changing my oil and filters. Well low and behold STUPID me... I put
    15w30 into the oil... DOH... Yah Yah Yah I know.. Anyways I redid it
    after my engine froze up on me a few days after that. That was when I
    decided to look at the containers of oil again... Noticing that 3 of
    them were 15w30.. my bad for not looking at them... Anyways.. I
    drained the oil, put new plugs, new filter and new battery in. The
    bike started up but the problem is the drain lines are syphing gas
    like a drunk gerbil with a bladder problem.. And the blueish white
    smoke wont stop, and my muffler looks like a smoking gun when I shut
    the engine off. Plus my carbs are always in need o being unscrewed to
    allow the fuel to be drained so it wouldnt cut out.. Can someone help
    me with this monumental screw up?
    Ceric, Jul 23, 2003
  2. Ceric
    Ceric Guest
    I already replaced all the carbs interior ONCE again. The leak is
    minimal now, but still have the problem of blue/white smoke. PLus now
    there is a knocking sound. I am beginning to think i need to Yank the
    cams and clean the valves and pistons and what not. What do you think?
    Ceric, Jul 24, 2003
  3. Ceric
    Eric Goforth Guest
    Hello,
    I had the same problem with my '89 Honda VTR 250. I didn't noticed the
    drain plug at first and figured that all the oil would come out with the
    filter, which is on the bottom of the sump. I can't remember what made me
    realize that I hadn't gotten all the oil out, but I started looking on the
    bottom of the engine and found the drain plug, and significantly more oil
    came out when I removed it.
    -Eric
    Eric Goforth, Jul 25, 2003
