1975 CB750 K5
Discussion in 'Motorcycle Technical Discussion' started by Matt, Oct 11, 2005.
  1. Matt
    Matt Guest
    Thinking of moving to a '75 Honda 750 with 13K miles and would like to
    know what good and bad points to look for with this model.
    Matt, Oct 11, 2005
  2. Matt
    Gary Walker Guest
    Hold on there Matt, you're really climbing the scale on
    the "state of the art" meter. <g>
    So, let's see, depending on the bike's anniversary, it's
    around 30 years old. At 13K miles, that looks like about
    430+ miles a year. No sense in burin' up the road, I guess.
    However, I suspect that rather than a linear 430 MPY, the bike was used more
    consistently in its early years,
    and then parked/abandoned(I'm only guessing) later.
    If it's had long periods of inactivity, I would be looking
    at bad tires, possible battery leakage/damage, and the
    presence of rust.
    I can't recall the K5, but I had a '73 K3. It was a four
    pipe model, and they were notorious for muffler rusting.
    Even back then.
    I would also be looking at the fuel purity coming out of
    the tank, as well as the same respect to the oil. Of course,
    these items could have just been cleaned/changed. Might
    want to drain a float bowl or two and check the gas there.
    Carefully check all rubber condition(front fork covers, if
    they exist, air intake tunnels, etc.). Put the bike on the
    centerstand, fire it up, put it in some gear, and let spin the
    rear wheel. Check the wheel for true. Run up the engine
    and check for exhaust smoking. Listen to the chain for
    and excessive noise or binding sounds. Listen to the engine for unusual
    noises. My K3 was a single OHC.
    Don't know when the DOHC models came about. It
    might have a noisy camchain. Obviously, look for any
    oil leaks, and if it's liquid cooled, and coolant leaks.
    The check list is endless....
    Gary
    Gary Walker, Oct 11, 2005
  3. Beyond the usual caveats when buying *any* old bike...
    The bike itself, by modern standards, is utter crap. It's massively
    heavy, requires enormous effort to ride any distance above about 80mph,
    and has truly terrifying brakes.
    It's detuned and slow. Expect 110mph top speed, or thereabouts (whatever
    the speedo says).
    I mean, there's a mount for an extra caliper on the 'other' fork leg,
    and Honda didn't fit one as standard. It's like saying: :"We know the
    brakes are crap, but if you want decent ones, you pay the extra, boy."
    Harley tried something similar with their 'aftermarket' brakes, which
    actually worked, unlike the ones they fitted as OE.
    The throttle is heavy. The suspension is crude and the whole chassis is,
    to be honest, completely at odds with the engine performance. It can't
    cope above, again, about 80.
    The lights are dire, the carbs need re-synchronising every 3000 miles,
    and the chain would disgrace a modern 125 and needs adjustment every 500
    miles and replacement every 5000. If neglected, it has a distressing
    tendency to part, and in extreme cases, this takes out the crankcases.
    The spokes in the rear wheel are not up to the abuse of the 60-odd bhp
    engine and loosen off or snap, with interesting consequences for the
    rear tyre.
    The high bars make the thing impossible to ride for any distance above
    (yep!) 80mph. There's a pattern emerging here, you know.
    And yet......
    It looks fantastic, if it still has a genuine 4 into 4 exhaust. It makes
    a lovely noise. It's reliable and easily maintained. And it is an utter,
    utter classic.
    In short, it's great for riding around below (guess what speed?). It
    turns heads. It has soul.
    The Older Gentleman, Oct 11, 2005
  4. If I was going to buy a 4-stroke I-4 built in 1975, I would look for a
    Kawasaki KZ-1000. It's a much better engineered motorcycle. It wouldn't
    matter if I had to pay more money for it.
    I'm not much impressed with Honda's early I-4's. The center of gravity
    is too high for the wheelbase. You can't remove the cylinder head
    without pulling the engine out of the frame (unless you take a hacksaw
    and cut the lower steering head braces out of the frame).
    krusty kritter, Oct 12, 2005
  5. Gary Walker wrote:
    Errmmmmm, if you aren't sure whether a K5 is air or liquid cooled, SOHC
    or DOHC, it might be better not to offer advice at all.....
    I ought to add - parts availability for the engines is till good. Even
    the OE 4/4 exhausts are available. Trim and cosmetic parts, like side
    panels and so forth, can be nightmares to source. It all depends on how
    original it is, and how original one wants it to be, I suppose.
    You're right about the four cans rusting, mind. They all did that.
    Squirting a load of oil down the silencers helped.
    That reminds me: recently I bought an utterly immaculate Honda CB125S,
    all original, clean as you will ever find, 1972 vintage. The OE exhaust
    was still in superb condition (it had been dry stored in a heated
    building). I discovered that these exhausts are now utterly
    unobtainable, and that not even pattern ones have the right style of
    silencer.
    So I recently bought a pattern system for a pushrod CG125 (which bolts
    straight on) and replaced the OE system wit this. The OE exhaust has
    had a pint of oil poured into it, and swilled around, and the faultless
    chrome has been coated in grease. It's sealed in a plastic bag, hanging
    in my garage, and when/if I sell the bike, it'll go back on.
    chateau.murray, Oct 12, 2005
  6. Matt
    Gary Walker Guest
    Well, not recalling a bike's manufacture history event is a
    lot different from not knowing of the that history. Did you see any text in
    my suggestion(s) that would make you believe I don't know what I'm talking
    about?
    Gary Walker, Oct 12, 2005
  7. Oh, the general advice applicable to old bikes is great - agree
    totally. But the answer to your question is, when it comes to this
    specific model, "Yes".
  8. I can recall the K5, my buddy had about a 1971 K1, and that was
    totalled in a crash with a taxi cab, so he made the insurance company
    buy him the K5 or he would sue them for the injuries sustained in the
    accident.
    Hey, a CB750 could be bought for as little as $1750 in those days of
    the Carter Recession. Such a deal! Everybody bought 'em, even people
    who didn't know how to ride...
    But this kid I knew was a real operator. He had an XS650 and he let a
    guy ride it and the guy hit a brick wall, so he demanded enough money
    to get the K1, which was wrecked in the taxi cab accident. Then he had
    the K5 for a few months and it was mysteriously stolen and he wound up
    with a Volkwagen. Yamaha to VW in less than a year. Hmmmm....
    CB750F was in 1979. There may have been 1978 DOHC's, check
    www.partsfish.com
  9. Actually, that was a problem that dogged *all* CB750s until the F2 and
    K7 came along with beefed-up O-ring chains.
    Damn nearly happened to me - it popped the spring link on the weedy
    chain, lost the sideplate, and the two halves of the link wre just
    opening out when I decided to stop for fuel and give the chain a lube at
    the same time =:O
    The Older Gentleman, Oct 12, 2005
  10. Matt
    Matt Guest
    What are the details and mechanism of crankcase damage when the chain
    breaks?
    Matt, Oct 12, 2005
  11. The chain breaks a hole in the crankcases around the countershaft
    sprocket.
    The sand cast cases certainly can't be heliarc welded, and the die cast
    cases probably can't be repaired either.
    By comparison, Kawasaki's 900cc Z-1 and the KZ-1000 are built like
    brick houses...
    krusty kritter, Oct 13, 2005
  12. Matt
    Matt Guest
    Could I replace the chain and sprockets with stouter parts? Maybe some
    previous owner has done that already?
    Matt, Oct 13, 2005
  13. I don't know if the chain and sprockets from the later models will fit.
    I don't see why they shouldn't, but it's not a conversion I've ever seen
    done.
    The Older Gentleman, Oct 13, 2005
  14. Matt
    thesewiv Guest
    I ride a K5 as a daily driver (well, I did until the base gasket
    started
    leaking. Can't show up at work with my right pantleg oil-soaked, so
    it's
    parked for the moment). I've got a Tsubaki 530 O-ring chain on it, and
    aftermarket sprockets. No problems with the install.
    I agree on the brakes, weight, and looks comments, too. I ride it
    because
    I like the "classicness" of the bike, and don't mind working on old
    bikes.
    80 mph is about the top you'll want to ride it without a windscreen.
    You'll want to look at www.vjmc.org, and wherever SOHC is hanging out
    now, I
    think it's www.sohc.net.
    It's a fun bike, IMO. Far from perfect, just fun.
    thesewiv, Oct 13, 2005
  15. I think that's fair....
    I've owned most of the SOHC Honda fours at one time or another. The
    very best, from a riding point of view, was the CB650 (believe it or
    not). Faster than all but the very fastest 750s, and handled and braked
    infinitely better.
    The 550s are a good compromise, but they're really thirsty, except for
    the four-piper K.
    I've still got a 400, which is (IMHO) the best of the lot. It
    completely outhandles all the others (with the possible exception of
    the 650), is smoother than the others, more economical, and looks just
    fantastic (again IMHO). However, it's a finicky little bike, and
    requires more frequent maintenance, especially oil changes and carb
    balancing. And it doesn't suit the large rider.
    Never ridden a 350, nor a 500.
    chateau.murray, Oct 13, 2005
  16. Matt
    Ed Cregger Guest
    Add a can of radiator stop leak in your crankcase next oil change. I
    guarantee it will stop leaking. <G>
    Just kidding, folks. DON'T DO AS I SUGGESTED.
    I actually heard of a woman doing that to her leaking automatic
    transmission. No, I didn't suggest it, either.
    Ed Cregger
    Ed Cregger, Oct 13, 2005
  17. Matt
    Ed Cregger Guest
    I still want to get my hands on a gray market 250cc inline four. I'd pull
    the mufflers and then revel in the sound of the little four cylinder revving
    up to 17k before shifting. That should make the hair stand up on (among
    other things) for any red blooded engine enthusiast/freak, such as myself.
    Ed Cregger
