1977 cb750 electrical problems
Discussion in 'Motorcycle Technical Discussion' started by rugger81, Aug 9, 2006.
  1. rugger81
    rugger81 Guest
    I just bought an old cb750 recently and now I'm having some electrical
    problems. I was riding down the rode when all of a sudden the bike
    stalled out. I pulled over to the side of the road and I noticed all
    the electrical was out. I tried kick starting it and push starting it
    and I even got someone to try and jump start the bike but all I got was
    the power to flicker a couple of times. The battery is brand new so
    that shouldn't be the problem. I don't have the money to go take it to
    a shop and get reamed so I want to try and fix it myself. I think
    maybe the power is shorting into the frame somewhere, but I don't know.
    Anyone have any advice for me? thanks in advance.
    -Joe
  2. rugger81
    monk Guest
    Try following through this fault finding chart. It helped me get through
    the electrical issues with both the bikes I'm working on. (74 RD350 and
    81 KE125)
    cheers
    monk, Aug 9, 2006
  3. rugger81
    monk Guest
    sorry, this is the link to the chart.
    http://www.electrosport.com/Images/fault_finding.pdf
    monk, Aug 9, 2006
  4. rugger81
    rugger81 Guest
    Looks like I got some work ahead of me, but at least I have some ideas
    of what to do now. Thanks alot guys.
    rugger81, Aug 10, 2006
  5. Reluctant to state the bleedin' obvious, but have you checked the main
    fuse and ascertained that you've done the battery terminals up tight?
    chateau.murray, Aug 10, 2006
  6. rugger81
    FB Guest
    Honda (and other manufacturers) may have done this to *protect* the
    alternator from
    overheating due to excesss voltage being generated during the daytime
    when the lights didn't have to be on, or maybe they thought it would
    save a little horsepower.
    But what it tended to do was cut the alternator output in half whether
    it was daytime or night time. That resulted in a lot of dead batteries
    when it became mandatory to run the headlight during daylight hours.
    The typical alternator has a 3-phase stator. Each phase generates about
    80 or 90 volts by itself, but, since the electricity has to return to
    another phase, the voltage across any two phases is 90 X 1.73 = 156
    volts.
    If any one of the three output phases has a bad connection, the voltage
    output is dropped by half, so the stator's power output is decreased by
    half.
    I use Tarn-X, a silverware cleaner that can be found in drugstores or
    supermarkets. After cleaning the corrosion off the terminals, I flush
    the Tarn-X off with distilled water.
    Tarn-X will remove the tin plating from electrical terminals if you
    leave it on too long.
    Somebody else recommended a product called DeOXit that supposedly works
    well.
    I found a 35-amp single pole single throw toggle switch and mounted it
    on a bracket on my handlebar.
    The red, blue, and yellow crimp eyelet terminals you can get in auto
    parts stores are especially bad. The Japanese used bullet and socket
    connectors. When I replace them, I solder them on.
    Motorcycles and cars and airplanes use stranded wire instead of solid
    copper wire because it's flexible.
    But the crimp type terminal only manages to use the outer strands of
    wire where they touch the terminal metal, but soldering terminals on
    makes the electricity go through ALL the strands of wire.
    Ordinary transformer wire from Radio Shack doesn't work. The enamel
    insulation won't survive being bathed in hot oil. The Japanese
    manufacturers used a special tough green plastic to insulate stator
    wires.
    FB, Aug 10, 2006
  7. rugger81
    rugger81 Guest
    I went over it with a voltmeter last night, and the bike was getting
    power up to where it starts going under the gas tank towards the
    handlebars. I took the gas tank off and gave everything under there a
    good check over and wiggle test but everything looked good. I gave all
    the wires up around the handle bars/behind the headlight a good wiggle
    test. I checked the three fuses it has for the main, headlight,
    taillight and all those were good. I just talked to my mechanic though
    and he said to check the fusible link by the starter solenoid. I'll be
    checking that when I go home for lunch.
    thanks
  8. rugger81
    FB Guest
    Do you have 12 volts at each set of ignition points when when they are
    open?
    If not, check back to the + and minus terminals on the coils. Then, if
    there's no power there with each set of points open, go back to the
    kill switch and the ignition switch.
    I'm not sure which one is first in the series, kill switch or ignition
    switch on your machine.
    But the ignition switch will be powered by a wire coming from the main
    fuse and from the battery, and it will energize a wire that goes back
    to the fuse box to power everything that works when the key is turned
    on.
    I have had iginition switches melt inside and have had other handlebar
    switches corrode so I couldn't start the engine.
    FB, Aug 10, 2006
  9. rugger81
    rugger81 Guest
    Thanks everybody, with your help I found the problem. The little
    switch at the base of the ignition it just old and worn out. Once I
    found out the ignition was getting power, I started to try and unplug
    the wiring harness from the ignition. The previous owner had it zip
    tied in place so after I cut those and started to giggle it out, I
    started getting a power flicker. So I took out the ignition, cleaned
    the connections and put everything back together, and it seems fine for
    now. Just in case however, I ordered a new base to the ignition, and
    will be putting it on as soon as possible. So it turns out it willd
    cost me less than $20 to fix my problem.
    thanks again
    rugger81, Aug 11, 2006
  10. rugger81
    Rides-A-Mule Guest
    I had the same problem with my 78' CB750. I dug thru one of my old gun
    box's and dug out a 22 bore brush, also got some fine sand paper 220
    grit and some electronics cleaner (spray type).
    Then I went thru every connection one the bike.
    BTW: I found the a digital camera really goes along way when doing
    the connection inside the headlight bucket. That can be a real horror
    show without some kind of guide.
    But lo and behold when I had finished my electrical problems
    disappeared.
    Good Luck to ya
    Rides-A-Mule, Aug 13, 2006
  11. rugger81
    G C Guest
    On my CBs, the ign switches have both died over time and exhibited the
    same scenario. (Was worse, every time you turned bars to left, it quit)
    Replaced ign switches. (25 each from CRC or PnM) All good now. Check the
    plugs and connectors. Good luck.
    Gopher Greg
    '77 CB750K Stock '78 CB750F AHRMA
    '00 ZG1000 Stock '96 Ducati 900SS Former track bike
    '01 GSXR750 Current race bike
    **********pull 'mychain' to reply***********
    ("I've abandoned the idea of trying to appear a normal, pleasant person.
    I had to accept myself as I was, even if no one else could accept me.
    For the rest of my life I would continue to say precisely the wrong
    thing, touch people in the raw and be generally unpopular. I had a
    natural gift for it" W. F. Temple)
    G C, Aug 15, 2006
