1980 CB750 F braking
Discussion in 'Motorcycle Technical Discussion' started by tokenhire, Oct 8, 2007.
  1. tokenhire
    tokenhire Guest
    My Honda 750 F Supersport is equipped with dual front discs, but does
    not seem nearly as capable at stopping as is should be.
    The calipers were rebuilt by a local backyard mechanic who was a
    little primitive in his technique the few times I was present for work
    being done. He claims that because the brakes are single caliper
    devices that the brakes are working as they should be. The rear brake
    is a better grabber than the front, so I am deeply skeptical.
    I believe the master cylinder should be replaced (there were some
    shadows of fluid around the resevoir lid seam when I got the bike and
    the lid is slightly bowed out).
    If there is anything I can do without having to purchase new caliper
    kits, I would be thrilled. But if anyone thinks that is the right way
    to go, please let me know so I can bite the bullet now instead of when
    I'm closing in on a deer at 57 mph.
    Thanks much!!
  2. Which model of CB750F? The DOHC version (as I strongly suspect), or is
    it an SOHC model that might have been languishing in a warehouse or
    showroom for a couple of years?
    Ignore Albrecht's comments about sintered pads - they really, really
    will not chew up those old Honda discs. At least, not within any
    significant mileage.
    chateau.murray, Oct 14, 2007
  3. tokenhire
    tokenhire Guest
    It is indeed the DOHC model.
    tokenhire, Oct 15, 2007
  4. I'd fit steel brake hoses. Nothing improves a set of old brakes like
    steel hoses.
    The Older Gentleman, Oct 15, 2007
