1982 Kawasaki 305 CSR Starting Question
Discussion in 'Motorcycle Technical Discussion' started by mpgmotors, Feb 11, 2007.
  1. mpgmotors
    mpgmotors Guest
    All,
    I am just not happy with how this bike starts when cold. The twin
    carbs have a little lever that opens the throttle plates on both carbs
    slightly when you set full choke on. I've gone through the carbs on
    this bike throughly and the carb passageways are all clear. The choke
    also shuts the choke butterflies completely as it also bumps open the
    throttle plates a bit as I mentioned.
    However, this bike is a bear to get started when cold - and it's been
    a lot of that lately. After it's running, using full choke gets the
    desired effect - RPM goes up to about 3-4K.
    I've been experimenting with different techniques to start it - full
    choke for a few seconds then half, almost full choke so that the lever
    doesn't move the front throttle plates, raise arms to the starting
    gods, spit on the ground and spin around twice before trying to start
    (which usually works) - all to no avail. I have the mixture screws out
    1 1/2 turns and when warm, runs fine.
    Any suggestions or history on these bikes - it's great otherwise.
    TIA,
    Pat
  2. Go to www.partsfish.com or to www.bikebandit.com and look at the
    CARBURETOR ASSEMBLY diagram.
    It looks to me like removing the choke link cam part number 13169
    (fast idle cam) would be simple enough.
    Potage St. Germaine, Feb 12, 2007
  3. mpgmotors
    mpgmotors Guest
    Thanks but I'm looking for some words on how that linkage should be
    adjusted rather than removing it.
    Bike Bandit is awesome for those pictures and their shipping too. I
    use them a lot and their prices match my local dealers exactly.
    Does anyone have a shop manual for a Kawasaki 305 CSR?
    mpgmotors, Feb 13, 2007
  4. Oh. I thought you were complaining about fast idling after starting.
    Kawasaki is the only manufacturer I can think of that used fast idle
    linkages. Riders seem to get nervous when their engines start up and
    idle at 4000 to 5000 RPM while cold.
    I wonder why cold engines screaming before they began to circulate the
    oil would worry somebody. ;-)
    It looks like you need the fast idle cam for two reasons. It links the
    choke shafts together and it has a hole for a spring loaded detent
    ball to drop into and hold the choke fully closed.
    Kawasaki was the last manufacturer I know of that used plate type
    chokes in the intake mouth of the carburetor. I haven't owned a
    motorcycle with a choke plate in over 40 years.
    The drill for starting a cold engine was to turn on the gas first.
    (Do you use the PRI position on the petcock to fill the float bowls?
    That helps when you have a vacuum petcock and it takes a while for
    fuel to start flowing.)
    Then I would kick the engine over a few times with the throttle about
    half open and the engine would blubber a bit as fuel was sucked out of
    the float bowl into the carburetor venturi and on into the cylinder.
    Blubbering was a sign that the engine "wanted" to start...
    Next, I would open the choke about 1/3rd and use about 1/4 throttle
    and kick again and the engine would fire up.
    Potage St. Germaine, Feb 13, 2007
  5. I hate it as well. Horrible thing to do.
    The Older Gentleman, Feb 13, 2007
  6. Have you adjusted the valves lately Pat? Had a problem getting my GPz
    started when cold, went through the carbs half a dozen times sure I had
    missed something. It ran like a top AFTER it was started but when cold was
    near impossible to start for fear of killing the starter I had to crank it
    so long. Someone from the KZR forum suggested I adjust the valves, I did,
    it now starts well and runs in the coldest temps (last week started it in
    minus 20 Celsius)
    Tom B
    ( If you want to test the theory, put a space heater under it for a bit too
    warm the bike prior to starting, if it starts probably the valve
    adjustments)
    somerushedcourier, Feb 16, 2007
