1983 Maxim 750 gas pouring out the exhaust
Discussion in 'Motorcycle Technical Discussion' started by Ron Dignard, May 15, 2004.
  1. Ron Dignard
    Ron Dignard Guest
    Hi
    I have a slight problem starting my bike this year, the bike will start and
    run at an idle but will not run if you give it gas. I noticed gas was coming
    out the drain hole in the left exhaust. I checked the No. 1 cylinder spark
    plug and it is wet, the cylinder is cold which tells me it is not firing. I
    checked the spark and it is good for that cylinder. Any ideas as what to
    check next?
    Thanks
    Digger
  2. Ron Dignard
    Charlie Gary Guest
    Without compression it won't light. Have you checked that, yet?
    Later,
    Charlie
    Fix the e-mail address and it will get to me
    There are about 100 different sorts of insects in Mexico that some people
    eat on purpose.
    Charlie Gary, May 17, 2004
  3. Ron Dignard
    SpongeHead Guest
    I had a similar problem with my old 2-cycle, ended up to be the jet in
    the carb. Gas was just flying out into the exhaust instead of a nice
    spray.
    SpongeHead, May 29, 2004
