1989 honda pinging
Discussion in 'Motorcycle Technical Discussion' started by grillinandchillinchef, Oct 21, 2005.
  1. i had a timing belt changed about 2 years ago and there was a slight
    ping on acceleration every once in a while but not always.
    is there any way a can adjust the timming without redoing the whole
    job, i alreay reatded the distributer all the way.
    thank you
  2. grillinandchillinchef
    Ed Cregger Guest
    An occasional ping is nothing to worry about.
    Ed Cregger
    Ed Cregger, Oct 21, 2005
  3. "Distributer"? Do Gold Wings have distributors, or are you talking
    about a "car"?
    Why do you believe that pinging has anything to do with spark timing?
    "Ping" is short for pre-ignition. The cylinder fires *before* the spark
    plug fires because the mixture is too lean or the spark plug ground
    electrode is glowing red hot or because carbon in the combustion
    chamber is glow red hot.
    You can cool the combustion chamber down by using higher octane
    gasoline or by richening up the idle mixture by turning the idle
    mixture screw in the rich direction, assuming your motorbike (or car)
    has carburetors. With a richer idle mixture, the engine should quit
    pinging.
    krusty kritter, Oct 22, 2005
  4. wrote in @g43g2000cwa.googlegroups.com:
    If the valve timing is truly off, then the engine is not running as it was
    intended. Usually the compression will be low and as such it will have less
    power than it is supposed to. You also will get poor mileage. I would
    verify first that the valve timing is correct or not. I would also adjust
    the ignition timing back to where it is supposed to be. Ignition timing will
    affect engine performance and mileage. Check your spark advance units. They
    could be stuck in the advanced position. The fix is obvious in that case.
    pierce
    R. Pierce Butler, Oct 23, 2005
