1994 suzuki gsxr1100 headlight please help
Discussion in 'Motorcycle Technical Discussion' started by Rick Reed, Jul 20, 2003.
  1. Rick Reed
    Rick Reed Guest
    The headlights on my '94 GSX-R1100 wont work, I tried replacing the
    bulbs and checked the fuse. What else might be the problem? The high beams
    only were working, now neither of them work (low or high beams). Has anyone
    run into a similar problem? What did they do? I want to get some ideas
    before I dig into the electrical. Thanks, -Rick
  2. Rick Reed
    Kevin Wells Guest
    In message <e%pSa.90512$>
    Sounds like an elecrical problem.
    Chase the wire for the headlight and see if it is worn.
    Kevin Wells, Jul 20, 2003
