1996 GSX750F (teapot) - yoke for flat bars??
Discussion in 'UK Motorcycles' started by bpwhitehouse, Feb 29, 2008.
  1. bpwhitehouse
    bpwhitehouse Guest
    Hi,
    I've removed my top yoke in order to find a replacement that will
    allow me to fit renthals to my GSX750F. Not having much luck tho,
    does nayone have any suggestions? Does it matter if the rubber damper
    pieces on top of the triple clamp line up with the new yoke etc etc or
    could I modify and sandwich a leaf of rubber sheet in between instead?
    Someone mentioned that I don't need the yoke, and can just use a set
    of adaptors and risers once the yoke is removed, like these:
    http://998cc.com/top_adapter_+_risers/310
    Are they talking nonsense -- seems feasible? However £100 seems steep
    for these little things?!
    Thanks,
    Bp
  2. bpwhitehouse
    steveloukes Guest
    Cant you just drill 2 holes in the top yoke , bolt these
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290208926999
    into said holes and then attach bars of your choice?
    Steve
    steveloukes, Feb 29, 2008
  3. bpwhitehouse
    MeerKat Guest
    Steve
    Check if a bandit 600/1200 top yokes will fit
    MeerKat
    MeerKat, Feb 29, 2008
  4. bpwhitehouse
    bpwhitehouse Guest
    Good idea - take the original yoke to a dealer and compare?
    Those ebay risers are an option - does the bottom stem incorporate a
    female thread so they can be bolted on? Because other than the clamps
    for holding the bars, I can't see how else they can be bolted on?
  5. bpwhitehouse
    steveloukes Guest
    Yeah - they are threaded so that you bolt them up underneath the yoke.
    Steve
  6. bpwhitehouse
    bpwhitehouse Guest
    Neat I think I shall bid to win them then!
