2001 Kawasaki W650
Discussion in 'UK Motorcycles' started by ST, Feb 1, 2007.
  1. ST
    ST Guest
    I've been looking for a new bike for a while and looking to upgrade...
    there are two W650s (which I am rather keen on) on fleabay at the
    moment, both around the £1200 mark with reserves not met. One has
    15km on the clock: (http://tinyurl.com/3x54y3) the other (http://
    tinyurl.com/2qh9ec) with a few mods - lower handlebars, altered
    filters, noiser silencers and a few scrapes has 77,000 miles (!).
    What would be the realistic sale price for these two shinier bikes?
    Parkers list them at £2500 or thereabouts for private dealer down to
    £1800 for private poor.
    Also what would the trade in value on a suzuki GN 125? 1999/T reg, few
    scratches on the tank, engine could do with a clean, about 8 months
    MOT left on it, quite a bit of pitting on the exhaust (which was re-
    welded on the last MOT). Would prefer a PX rather than private sale
    to get the money out and put towards something newer and shinier, in
    time for the nice weather.
    Any input appreciated (even of the 'why not a bonnie?' variety).
    ST, Feb 1, 2007
  2. ST
    BORG Guest
    I quite like the looks of these bikes
    www.ratrodz.co.uk
    XJ900 Trike ** GS850 Trike
    XV1000 TR1 Chop
    [Rot 13 it]
    Some people are like slinkys....
    no real use but it makes you smile when they fall down stairs!
    BORG, Feb 2, 2007
  3. ST
    Simes Guest
    BORG said:
    No-one can accuse you of failing to help.
    Simes, Feb 2, 2007
  4. ST
    ST Guest
    Yeah they are nice aren't they...I'm looking for something with a bit
    more grunt than what I'm currently riding (which shouldn't be
    difficult), comfy enough for long-ish runs but nothing to scare the
    shit out of me.
    ST, Feb 2, 2007
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    Is this a new rule? When was the vote?
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Feb 2, 2007
  6. ST
    Simes Guest
    That dear old chap, Wicked tugged on his old shag and said:
    Last wednesday. About teatime.
    Simes, Feb 2, 2007
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    Oh bugger.
    <thread swerve>
    You wouldn't have a spare Pan ABS/TCS rear caliper and bracket about
    your person, I suppose?
    Mine's started sticking *again*, and I can only conclude that after
    105,000 miles it's a bit tired and shagged-out. The pistons seem free
    enough, so I think it must be the sliding pins that are past their best.
    I'm going to ring that nice Mr Silver tomorrow, just for a laugh, then
    I'm going to start calling round breakers.
  8. ST
    ST Guest
    Oi ! Thats enough of that!!!!
    ST, Feb 2, 2007
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, ST
    NAHAY?
  10. ST
    Simes Guest
    Oddly I haven't...
    The only time mine stuck (settle down at the back) was when the pins
    were covered in shite. Whip out the pads and grease (coppaslip is what
    I use) the slidy bits - the bolt that locates the caliper (the 14mm
    headed one on the swing arm etc) and that usually sorts it.
    Nah - it's fucked - I'll take it off your hands for a tenner - if you
    deliver.
    Simes, Feb 2, 2007
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    BTDT. Here's a funny thing, though. The caliper bracket is gripped quite
    tightly between the spindle and the bearing spacer in the wheel when the
    spindle bolt is tight, yes? So there's no radial play in it.
    So the 14mm headed pin ends up pressed quite tightly against one side of
    its orifice. So it can't slide very well, even if it's greased. Now,
    that's OK, since it's attached to the caliper bracket, and quite clearly
    that can't move sideways, can it?
    So why does it *look* like it ought to slide? ;^)
    I may get back to you on that.
  12. ST
    Simes Guest
    That's Mr Honda's bit of fun. Every bike has one.
    The caliper itself slides on little hidded pins IIRC. They stick and
    make the 'inside' pad bind. You need to take the whole caliper off and
    clean until you can clean no more...
    Then have hours of fun bleeding the bugger.
    This is a time limited offer - don't delay, reply today.
    Simes, Feb 2, 2007
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    Yep, I've done that. I think they're just worn to the point that they're
    not playing any more. If it was just the pins, I'd have a go at making
    new ones, but the bores will be fucked too, and sleeving them falls
    under "waaaay too much like hard work". Time to spend some money.
    Amusingly, I just checked the HBoL and it says that Honda recommend
    changing the caliper stopper bolt every time it's removed. Uh-huh, yeah
    right. I might treat it to a new one this time though.
    Oh yes. Having said that, a Mityvac does make it a bit easier.
    Oooh, pressure. I *hate* pressure.
  14. ST
    Simes Guest
    On the bright side, the scrappers have more bikes with fucked front
    ends than they do with fucked rears. So you stand a good chance of
    getting the wole assembly for a few bob.
    Indeed. TBH it doesn't look like the sort of flimsy thing that's going
    to fail too often does it?
    So will your brake system after you take the caliper off.
    Simes, Feb 2, 2007
  15. Parkers is well optimistic as regards private prices. You can get a
    decent one for £1500 privately, and a corker for £2k. Both the ones you
    list are from traders, and I would not touch either (one's a grey import
    and the other is a shed).
    A dealer wouldn't be interested. It sounds a bit of a shonker. Any 125
    with a valid MoT will sell on Ebay, though. Sounds like £450-500 worth
    privately.
    The Older Gentleman, Feb 2, 2007
  16. On a performance per £ basis, there are *a lot* of better choices.
  17. ST
    Spete Guest
    I quite like the look of those calipers :)
    Spete, Feb 2, 2007
  18. ST
    Simes Guest
    That dear old chap, Spete tugged on his old shag and said:
    Nice one centurian.
    Simes, Feb 2, 2007
  19. ST
    ST Guest
    Privately it is then. Its not in great nick to be fair so that price
    range sounds about right.
    Ive had a look on auto trader for W650s' (I know, I know - previous
    comments taken on board) and most are over 2500 (some up to 3000) -
    all with traders. There is one for 2k in bradford with 22k miles on
    it which looks interesting - might follow that up.
    I was suprised to find the 3rd party insurance was only £200 with
    auntie carol, given the pikey area I live in.
    What are the things to look out for (bearing in mind I have a level of
    mechanical fuckwittedness probably far in excess of most people on
    here) if buying through a trader?
    Again any help appreciated.
    ST, Feb 2, 2007
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    I've just got off the phone from Uncle David. £300-ish complete,
    bracket, caliper, pistons, seals, nipples, the whole deal.
    <small wince>
    **** it, it's only money. Two weeks delivery. At least I'll have a
    working rear brake.
