2003 HD Sportster XL Custom
Discussion in 'Motorcycle Technical Discussion' started by Debi, Jul 18, 2006.
  1. Debi
    Debi Guest
    I'm having some problems with it dying on me while riding.I'm not sur
    whats going on but I took my kid for a ride and we ran out of gas, so
    pulled or should i say we pushed it and filled it. Then all of a sudde
    it stopped running and shut down. Had to wait awhile before startin
    it.It was hard to start and seemed like if I gave it gas it stil
    wouldnt turn over. When it did start I went on only to have it buck o
    me and then die again. I've heard it could be an ignition problem? An
    suggestions
    Debi, Jul 18, 2006
  2. Debi
    FB Guest
    Does that model have a Mikuni constant vacuum carburetor on it? If so,
    I will tell you the same thing I tell people who have Japanese
    motorcycles with Mikuni or Keihin constant vacuum carburetors with the
    big round cover on top.
    Those carburetors have really tiny idle passages and really large idle
    jets. It doesn't matter how big the idle jet is, if the idle passages
    get plugged up with gum and varnish, the engine will idle OK, but it
    will die when you open the throttle.
    You might try putting about 3 ounces of Berryman's B-12 Chemtool Choke
    and Carburetor Cleaner in a full tank of gas and going for a putt. The
    B-12 will clean out the carburetor and the idle RPM will increase, so
    you may have to stop and turn the idle speed down.
    Find out where your idle speed knob is and get to know and love it. A
    rider who doesn't know where the idle speed knob is shouldn't be riding
    anyway.
    You can buy Berryman's B-12 at Wal*Mart for less than $3.00 for a 15
    ounce can of the liquid kind, or you can buy the aerosol can and spray
    it into a measuring cup before dumping it in the gas tank.
    No, I do not own stock in Berryman's or in Wal*Mart, and I do not
    distill Berryman's in a shed out in the woods. It's just that the stuff
    is so cheap and it cleans out carburetors so easily. I use B-12 in my
    gas tank about three or four times a year to keep my carburetors clean.
    FB, Jul 18, 2006
  3. Debi
    Gary Walker Guest
    It's never a good idea to run any vehicle out of fuel. Both
    for obvious reasons, and reasons such as this.
    Gary
    Gary Walker, Jul 18, 2006
  4. Debi
    OH- Guest
    Something that sounds daft but actually happens is that the air
    inlet in the tank cap gets blocked. This will create enough vacuum in
    the tank to stop petrol flow after riding for some time.
    You can test if this is your problem by opening the tank cap the
    next time you experience the same problem. Listen for a whoosh
    sound. If the engine starts and runs fine after just opening the
    cap this could be your problem.
    OH-, Jul 18, 2006
  5. Debi
    GaZ Guest
    Or it could just be that the 'original' fault was not lack of fuel?
    GaZ, Jul 19, 2006
  6. Debi
    OH- Guest
    Please explain both the "obvious" reasons and how this relates
    to the original posters problems.
    OH-, Jul 19, 2006
  7. Debi
    Gary Walker Guest
    Well. the obvious reason(s) is/are :
    You may have to walk
    Your passenger may have to walk
    You & your passenger may have to walk, and walk a
    very long distance.
    You may have to buy a gas can that you'll either discard
    after refilling the bike, or have to tote with you.
    Your bike could be stolen while you're hiking for gas.
    You bike could be vandalized while you're hiking for gas.
    I've recently heard of various city imposed towing of
    vehicles abandoned on their highways. I suppose that a
    dry fuel motorcycle, with an out of sight owner just might
    qualify.
    "Are you catching on yet"?
    And, regarding the relevance to the OP's dilemma:
    Many times, but not always, I have seen vehicles run very
    poorly, or not at all, after allowed to run dry on gas. This
    has usually been attributed to a residue trash entering the
    system in the absence of fuel. Although just theory, it can
    certainly be possible. So, why create the exposure?
    Questions?
    Gary
    Gary Walker, Jul 19, 2006
  8. Debi
    Debi Guest
    Thanks guys! It ended up needing a new air filter, a new 190 jet and
    circuit breaker. Well it should be ready for saturday. Thanks all fo
    your help
    Debi, Jul 20, 2006
  9. Debi
    OH- Guest
    OK, that was a bit too obvious for me. As we mainly post
    about the technical aspects of motorcycling here, I
    thought you meant some sort of direct damage caused
    by running dry.
    Now that there are more and more bikes that have
    catalytic exhaust cleaning, there might actually be some
    good technical reason not to run dry on these models.
    OTOH, bike catalytic systems are AFAIK a bit different
    from on cars.
    Let's stay away from "vehicles" and stick to bikes. We
    don't want to even think about old diesels where you were
    in for a spannering orgy of venting and priming if you ran
    dry.
    In an old fashioned bike tank with a reserve position on
    the petcock, the critical moment is when you turn on the
    reserve. The fuel is then taken from a point much closer
    to the bottom of the tank and the engine can get a gulp
    of for example water that has been sitting at the tank
    bottom.
    If the bike does not have a screen around the tank outlet
    there could be a lot of rust or other crap as well. Anyone
    running a fuel system with no filtration deserves this.
    If there is no reserve position, maybe not even a petcock,
    there will be no lowering of the fuel outlet point and any
    crap will flow into the carb no matter how much fuel is
    in the tank. Until the tank is empty, of course.
    On bikes with fuel injection, where I have no personal
    experience, I guess it will take a while to flush the air out
    of the system.
    OH-, Jul 20, 2006
  10. Debi
    Gary Walker Guest
    My 2000 Honda has never even seen reserve. Not bec-
    ause I fear some kind of operational abnormality, I just
    try to keep the tank full. My earlier reference to "vehicles"
    was merely meant to preclude someone's comments that
    "hey, that can happen with cars too".
    Personally, I've never run any vehicle type out of gas. But,
    I've witnessed others do it, sometimes with no harm, other
    times with similar consequences as described by the OP.
    But, it seemed like some additional factors were present
    in her/his final diagnosis.
    Gary
    Gary Walker, Jul 21, 2006
  11. Debi
    FB Guest
    Well, it might have been electrical. If the electrical circuit to the
    ignition doesn't make good contact, the motorcycle just might buck and
    jump as the ignition cuts out irregularly.
    The 190 main jet would have nothing to do with the starting problem you
    described, you only use the main jet when the engine is running at wide
    open throttle and that occurs about 1% of the time for cruiser riders.
    The air filter is a maintenance item. It would have to be very dirty to
    keep the engine from starting.
    FB, Jul 21, 2006
  12. Debi
    Debi Guest
    Ok maybe I have someone who is fixing my bike and knows nothing,
    don't know. All I know is that it still bucks and then in a while i
    will shut down . Im at my wits end. I would take it to Harley but I'l
    pay a mint. My brothers friend is a Sportster racer and fixes his ow
    bikes. I hope he can fix it
    Debi, Jul 22, 2006
  13. Debi
    FB Guest
    Well, all those certificates on the wall at a mechanic's work station
    are no substitute for experience. The mechanic goes to the school, pays
    the fee, and they are going to give him the piece of paper he paid for.
    If mechanics went to the Motorcycle Mechanics Institute and didn't
    pass, they wouldn't get more students would they?
    Try the Berryman's B-12 carburetor cleanout I recommended.
    Mikuni constant vacuum carburetors have really tiny idle passages and
    really large idle jets. It doesn't matter how big the idle jet is, if
    the idle passages get plugged up with gum and varnish, the engine will
    idle OK, but it will die when you open the throttle.
    anyway.
    Well, he should at least be able to show you the idle speed knob. Shade
    tree mechanics have a lot of enthusiasm, but they tend to have
    simplistic ideas about what might be wrong with a machine and they
    really do not understand constant vacuum carburetors.
    It took me thirty years to find out why constant vacuum carburetors do
    some of the mysterious things they do.
    Then there is the business with the circuit breaker. Many mechanics
    will experimentally replace electrical parts that they don't understand
    the function of.
    The circuit breaker is like a fuse, except there is a button to reset
    it if it trips off because of electrical overload.
    If you had too much electricity flowing through the wires and that made
    the circuit breaker trip off to protect the circuit, replacing the
    circuit breaker would be most illogical, as it wouldn't fix the reason
    for the electrical overload and the wiring would eventually burn up.
    It is conceivable that the electrical contacts inside the circuit
    breaker weren't making good electrical contact though.
    But you say that the motorcycle still bucks after the circuit breaker
    was replaced, so I recommend cleaning out the carbs with B-12.
    And, you can check all the electrical connections coming out of the
    ignition switch and the connections on the ignition coils and the
    signal generator and the ignition control box to see if they are tight.
    Your brother's friend should be able to help you find all those
    connectors.
    FB, Jul 22, 2006
  14. Debi
    FB Guest
    While I was thinking about loose electrical connections, you might also
    look at the side stand and the clutch lever to see if there are
    electric switches that are operated by moving the clutch lever or
    putting the sidestand up or down.
    I don't think Harley Davidson puts things like that on their
    motorcycles yet, but all the
    Japanese manufacturers do. And dirty contacts in side stand switches
    will cause the motorcycle to suddenly buck and the engine will quit.
    Also, if the engine quits like that, work the kill switch and turn the
    ignition key on and off and feel the back of the ignition switch if you
    can get your hand behind it.
    If the ignition switch is getting really hot, it has bad contacts and
    can cause the engine to shut off unpredictably.
    FB, Jul 22, 2006
  15. Debi
    FB Guest
    Yeah, like when your GF backwashes in your coffee and it tastes funny,
    but you drink it anyway, because it won't hurt ya?
    Whoever gave you that advice wasn't thinking about what tiny bits of
    rust and dirt can do to the tiny passages in a Japanese carburetor.
    Even if you have an add on gas filter, water will go right through it
    and build up in the float bowls.
    So my recommendation is to NEVER use the reserve position on the
    petcock unless it's a real out of gas situation and you are stuck miles
    from a gas station.
    FB, Jul 23, 2006
