2005 ZZR600 - Engine chocking at over 50Mph, please advise
Discussion in 'Australian Motorcycles' started by efskyline, Aug 22, 2005.
  1. efskyline
    efskyline Guest
    A friend of mine just bought a used ZZR600 with 1600 miles on it with a
    known and admited issue on it. From what my friend was told by the
    previous owner, one fine day the bike just begun to choke at high
    speeds. Here's what I discovered when I actually rode it home from
    Jersey to NYC. It starts fine, revs beautifully, getting to about 45mph
    with no issues whatsoever. But once you're up to 50mph or so,
    regardless of what gear you're in or how high the RPMs are, the engine
    starts choking and stalling out. It doesn't shut off completely, nor
    does it produce any power, it just keeps jerking back and forth between
    gaining some power and then loosing it. It pretty much limits the speed
    of the bike to around 60mph even with full throttle. Once again, the
    engine never cuts out completely. While parked, I was able to rev the
    engine to 9K RPM and it sounds clean, no skipping or choking of any
    kind and getting great throttle response. Could someone point us in the
    right direction as to what the issue could be? Thanks in advance.
  2. Whats a "mile"?
    Dr Harold Shipman, Aug 23, 2005
  3. 1.6 kilometres.
    HTH.
    lemmiwinks.au, Aug 23, 2005
  4. efskyline
    Nev.. Guest
    Optimax.
    Nev..
    '03 ZX12R
    Nev.., Aug 23, 2005
  5. efskyline
    atec Guest
    might be nautical , 1.840(approx)M
    atec, Aug 23, 2005
  6. efskyline
    Nev.. Guest
    1.84 metres ?
    Nev..
    '03 ZX12R
    Nev.., Aug 23, 2005
  7. efskyline
    Toosmoky Guest
    A Mille with the "l" thrashed out of it.
    Toosmoky, Aug 23, 2005
  8. efskyline
    alx Guest
    nah...if you dont know whatz wrong, try spraying some WD40 around the place.
    alx, Aug 23, 2005
  9. efskyline
    John Littler Guest
    About 6 feet then ?
    HTH, HAND.
    JL
    John Littler, Aug 23, 2005
  10. His ZZR only does 300 feet per hour? I didn't know Hardley made a bike
    called a ZZR...
    big
    Iain Chalmers, Aug 23, 2005
  11. efskyline
    John Littler Guest
    Well the engine is chocking, and you know Lebs don't like working too hard.
    JL
    (but I'll bet it's foilly soike moite)
  12. efskyline
    G-S Guest
    They don't... it's a licensed version of the Monster 620 lite :)
    G-S
    G-S, Aug 23, 2005
  13. efskyline
    GB Guest
    It would probably go quicker if he pulled the chocks out from
    in front of it.
    GB
    GB, Aug 24, 2005
  14. Probably,since he rode it from Jersey--that's why it's flooded.
    Postman Pat
    Pat Heslewood, Aug 24, 2005
