2009 motorcycling highs and lows
Discussion in 'UK Motorcycles' started by The Older Gentleman, Dec 31, 2009.
  1. The Older Gentleman
    Dan L Guest
    I really liked my post DAS CB500, an excellent all rounder
    Dan L, Jan 2, 2010
  2. The Older Gentleman
    YTC#1 Guest
    Mine, spending a whole month on the bike (XJ900) doing Europe from end to
    end.
    Finaly getting to Applecross and hooning around Scotland between heavy
    showers.
    Coming into Carcassone over the mountains after 19 days on the bike, the
    headlight falling out and momentarilly wanting to just go home.
    Getting home and wantong to go round again :)
    YTC#1, Jan 3, 2010
  3. The Older Gentleman
    YTC#1 Guest
    Its getting to be a bit of a tart that bike, isn't it :)
    YTC#1, Jan 3, 2010
  4. The Older Gentleman
    High points:
    For me it'd have to be doing the Elefant on the outfit with Platy as
    co-pilot. The fucking beast handled worse than anything I'd ridden
    before yet we both kept laughing. The actual rally was it's usual riot
    of bad behaviour and large amounts of alcohol which is due to be
    repeated in a couple of weeks by some of us.
    The French run and Chimay were great and the Alps trip was a roller
    coaster ride swinging from low points to high points within hours on
    several occasions.
    Riding the Tenere to Stafford for the bike show the day after having a
    load of stitches removed from my hand. I wasn't sure I was up to
    riding the distance and when I got there and noticed that my finger
    needed stitching again I realised how addictive bikes are.
    Being told by German plod to leave the country on two separate
    occasions has to be a high point.
    Low points:
    Crashing the 10R.
    I suppose getting nicked by German plod could be classed as a low
    point but sitting outside the nick watching burnt try to video the
    cops noise testing Krustys MV was fucking hilarious.
    All in all it was a pretty good year and with a bit of luck this one
    will be just as entertaining.
    Andy Bonwick, Jan 11, 2010
  5. To be fair, that was the high point for some of us.
    Almost as amusing as TOG failing to get the Ducati running on the trip
    to the Bol d'Or in '99.
    Shame I fucked the recording up 'cos Krusty was looking very worried.
    Picture'll have to do:
    http://www.flickr.com/photos/8963323@N05/3893197863/
    stephen.packer, Jan 16, 2010
  6. The Older Gentleman
    S'mee Guest
    <snork> further proof man ought to keep the stock exhaust... I mean
    really, all aftermarket does is look pretty make noise and draw
    unwanted attention. 8^) Any power gains you gain from an exhaust is
    pointless without major fueling modifications.
    S'mee, Jan 16, 2010
  7. The Older Gentleman
    ginge Guest
    Krusty has got a stock exhaust.. It's just the some[1] of the
    internal baffles may have, erm, become detached somehow..
    [1] all.
    ginge, Jan 17, 2010
  8. The Older Gentleman
    S'mee Guest
    Like I said... ;^) That's okay though. I seem to recall a certain
    feature on a certain suzuki that opened up the exhaust and let you
    clean the baffles with a blow torch...sure uncorked the 2smoke in the
    process also.
    S'mee, Jan 17, 2010
  9. Most Suzi 2-strokes had removable baffles. A wood fire was good,
    you could throw the baffles in the fire and recover them cleaned from the
    ashes the next morning. I had security banging on the lab door once when
    I tried to decoke/deoil the T500's exhaust pipes. I'd stuck the header
    pipes in the extraction port from our welding area, turned the fan on
    high, started the crud burning with an oxy torch, then turned off the
    acetylene and blasted it with pure oxygen. I couldn't see how much smoke
    was coming out of the extraction vent...
    Dr Ivan D. Reid, Jan 17, 2010
  10. The Older Gentleman
    And in many cases save several kilos of weight & allow significant
    power increases.
    A power gain is a power gain you muppet. How can it be 'pointless' just
    because you don't like the bit of metal it comes from? If you mean you
    won't get the power gains from an aftermarket exhaust without changing
    the FI/jetting to match it, then yes, obviously. But it's hardly 'major
    fueling modifications'.
    Krusty, Jan 17, 2010
  11. The Older Gentleman
    Nah, that was in quiet mode, it still had the tailpipe baffles in.
  12. The Older Gentleman
    zymurgy Guest
    Aye, I remember the time she made me and several other UKRM'ers
    welcome in your house when you were laid up in hospital.
    Heh, in my case, unfortunately not 'almost' :/
    Paul.
    zymurgy, Jan 17, 2010
  13. The Older Gentleman
    S'mee Guest
    ROTFLMAO!!! That's why I did it outside and yeah I was working on T500
    also (72 model to be exact) Things go right this year I'll likely be
    getting a new set of oil lines for mine from Crook's Suzuki. It's a
    compleate basket case adn I HOPE the crank isn't too rusty to clean up
    and have rebuilt. My proclivity for castor over the others is with
    good reason...high temp lubricity.
    S'mee, Jan 17, 2010
  14. The Older Gentleman
    S'mee Guest
    lol.
    S'mee, Jan 17, 2010
  15. The Older Gentleman
    S'mee Guest
    That's the ONLY story I'll buy. 8^) Weight saving is a GOOD THING...
    heh, your definition. I wont argue the point.
    S'mee, Jan 17, 2010
  16. Off the top of my head, can't recall if mine was '71 or '72 -- T500R
    (unfortunately not TR500...) in purple-and-white.
  17. The Older Gentleman
    S'mee Guest
    Blue and White with that nice <rolls eyes> red pin stripe...that bit
    is a decal. Likely keep the stock intake and exhaust. Modernize the
    tail light with salvage specials tail lights. <wink> Not worrying on
    the fiddly bits UNTIL the motor is done and running properly.
    Fortunately the stock exhaust isn't rusted out and the baffles are
    fine...the sucking sound you hear is me jetting it for my altitude
    (3,782ft with Marias Pass (el. 5213 ft./1588 m.)) just down the road
    (roughly 60mi)
    Going to make things interesting...and before you ask the cases aren't
    going to be polished. I prefer the 30+ year old patina on the
    aluminium. <shrug> guess that makes me weird.
    S'mee, Jan 17, 2010
