2009 Unargural in 72 seconds
Discussion in 'Australian Motorcycles' started by Marty H, May 21, 2009.
  1. Marty H
    Diogenes Guest
    Ewww... too esoteric of me...
    Onya bike
    Gerry
    Diogenes, May 23, 2009
    #61
  2. Marty H
    G-S Guest
    I have considered a trailer to be honest, that would certainly give me
    enough space :)
    G-S
    G-S, May 23, 2009
    #62
  3. Marty H
    G-S Guest
    <applause>
    G-S
    G-S, May 23, 2009
    #63
  4. Not easy too see Gerry?
    George W Frost, May 23, 2009
    #64
  5. Marty H
    fixed... just for you George
    [applause] I was expecting Yackety Sax (the Benny Hill theme)
    Knobdoodle, May 23, 2009
    #65
  6. Marty H
    Yeebok Guest
    OK - the most likely candidate is Jupiter if it was recent - the moon
    moves pretty quickly through the sky so date/time would be handy - other
    wise it could be almost anything.
    Yeebok, May 23, 2009
    #66
  7. Marty H
    Diogenes Guest
    George... I was clearly being too esoteric for _you_.
    Clue[1] Goto http://216.92.113.163/item.php?item_id=240 this
    relates to a Meade 1060-Research Series (10 inch Newtonian-Equatorial)
    telescope.
    Clue[2] On that page, under the heading "Why I obtained this
    Scope", you will find the following words: "I was introduced to the
    world of catadioptrics and esoteric telescope systems".
    hth
    Onya bike
    Gerry
    #67
  8. In aus.motorcycles on Sat, 23 May 2009 16:04:01 +1000
    The towbar's the same as the Breva, Classic Industries fitted mine and
    they had it in stock.
    You have to cut slots in the tailpiece for the bars that go from the
    rear subframe to the towbar. I fitted LED lights to the trailer,
    seemed to work better than normal ones.
    I suspect the 4' x 3.5' trailer frame from easytrailer.com.au would work
    well as a general purpose bike trailer with a bit of homework as to
    box/platform.
    Zebee
    Zebee Johnstone, May 23, 2009
    #68
  9. 3 weeks ago and close to the moon the most likely candidate would be
    Saturn, both low in the northern sky around 7:00pm. Saturn can appear to
    be bluish-white; Jupiter is more orange-white. Jupiter has not been
    visible close to the moon for a long time.
    Andrew McKenna, May 23, 2009
    #69
  10. Okay, make you own mind up with these
    http://s278.photobucket.com/albums/kk91/georgewfrost/Planet 2009/
    three photos, one of the moon and the whateveritis
    the others are the moon and the thingamyjig
    #70
  11. Marty H
    G-S Guest
    I'd be a bit concerned about the wheel bearings in those running loaded
    at speed to be honest.
    I'm sort of leaning towards an ali-lite.
    G-S
    G-S, May 23, 2009
    #71
  12. You missed it Gerry, right over the top
    I was referring to the bike, the Newton Commando
    or for you, a Norton Commando
    so I asked: ""Not easy too see Gerry? ""
    Norton ESII ( an Easy 2 Gerry )
    Gerry, you must get back on your medications
    #72
  13. Marty H
    bt Guest
    Buggered if I know, but I can assure you that apart from very close
    comets and maybe a nova in our own galaxy, no night-sky object is
    going to be brighter than the full moon. If it was near the horizon
    just after sunset it might have been Venus.
    This link shows some events like that which have happened or will
    happen this year:
    http://home.mira.net/~reynella/skywatch/ssky.htm#update
    As far as seeing Mercury, to my knowledge from an earth-bound vantage
    point it will never be more than 1 or 2 degrees away from the sun (and
    1 degree is approximately the width of the solar or lunar disk). I've
    been wrong before, though.
    bt, May 23, 2009
    #73
  14. Marty H
    bt Guest
    Touche! Well done, sir! ;-)
    bt, May 23, 2009
    #74
  15. Marty H
    bt Guest
    Eh? There was me thinking that the Earth and Venus were about the
    same diameter (~12,000km)?
    http://nssdc.gsfc.nasa.gov/planetary/factsheet/venusfact.html
    I'm no astronomer, mind you... ;-)
    bt, May 23, 2009
    #75
  16. Marty H
    bt Guest
    Don't you already own an outfit? How big is this bloody telescope of
    yours anyway?
    bt, May 23, 2009
    #76
  17. Marty H
    bt Guest
    bt, May 23, 2009
    #77
  18. Marty H
    Smeeegles Guest
    So how did you keep the shutter going?
    remote or did you sit there snapping each frame under continuous shooting?
    Smeeegles, May 23, 2009
    #78
  19. Marty H
    gwd Guest
    Amazing!! Who would have thought it could be that!
    gwd, May 23, 2009
    #79
  20. Marty H
    G-S Guest
    G-S, May 23, 2009
    #80
