300 Pound 40 HP Machine for Two Riders
Discussion in 'Motorcycle Technical Discussion' started by Nomen Nescio, May 14, 2005.
  1. Nomen Nescio
    Nomen Nescio Guest
    The Bergman 650 ABS is a dream machine with the exception of two minor
    deficiencies: It is at least 150 pounds overweight and it lacks sufficient
    engine assisted braking. Fix those two items and leave everything else
    alone for the remainder of the century.
    Side note: ABS has to be the greatest innovation applied to motorcycles
    since the abandonment of the suicide clutch. Krusty would have given his
    right leg for ABS on his CB350.
    First the fat problem. A 300 pound (dry) motorcycle, with an extra low
    c.g., that carries a payload of 300 pounds is very doable and will feel
    more like a moped than an XLH to the rider's delight. Replace the piston
    engine with a fuel efficient turboshaft engine, ganged planetary and CVT.
    Problem solved. Details: A 40 hp. turboshaft is no larger than an
    automobile starter motor and weighs no more, including the reduction gear.
    It is so simple and has so few parts, it makes you wonder why its taking so
    long to build it into motorbikes. Contrary to popular belief, a gas turbine
    is not a fuel hog if its run at a constant speed. The Chrysler Turbine Car
    was a gas hog because it was run with a throttle and hooked up to a
    TorqueFlite. A CVT is able to couple a constant speed engine to the rear
    wheel from zero to 100 mph. I calculate a 40 hp turboshaft will use no more
    than one gallon per hour in normal riding, about the same as the 650 twin
    used currently. The entire power train should weigh no more than 80
    pounds, saving at least 100 pounds of weight. Another 50 pounds can be
    saved on the frame and accessories by using chrome moly, aluminum,
    titanium, and carbon fiber.
    Next the braking. At speeds below 30 mph, leave the braking system as is.
    But, above 30 mph, the CPU can do some wondrous things for this bike. The
    turboshaft normally runs at a modest 40,000 rpm. With a 10 or 20 pound
    flywheel on its mainshaft to add some rotational inertia, regenerative
    braking can be back-coupled through the CVT to boost this to 80,000 rpm.
    This extra stored energy under your seat can be controlled by the CPU and
    used again for acceleration. During the regenerative phase, the bike will
    feel exactly as a BSA 650 when the throttle is rolled off and that is
    reassuring. On very long downhills, or from repeated braking, the rpm will
    be limited to 80,000 and excess energy can be absorbed in the turboshaft
    compressor, bled off to the atmosphere, fuel cutoff and exhaust choked.
    The whole process will be seamless and the bike will slow down as if by
    magic. Regenerative braking has the beneficial effect of boosting economy;
    in stop and go traffic, the engine may never even light up. A very
    important point is to utilize CPU logic to control regeneration in
    conjunction with ABS and accelerometers to make it feel as though the
    engine is doing all the work, with no surges of extra power or sags of lost
    power. Smoothness is everything. No one is interested in coupling an
    80000 rpm flywheel suddenly to the driving axle and exploding the tire in
    blue smoke.
    A few more embellishments are notable. A turboshaft is one of the
    cleanest engines around. Its exhaust is so benign, it can be routed to
    exit at the rider's feet so as to provide a gentle warm fresh air flow for
    comfort on those chilly morning rides. A turboshaft also needs no muffling
    at all and this saves weight and expense. All it emits is a subdued whine
    which riders will soon appreciate as the whine of power and prestige. A
    turboshaft may cost nominally more than a piston engine, but lets not
    forget the Burgman is not cheap; quality costs and conaseurs of the better
    things in life are all to happy to pay for it. Given an efficient
    aircleaner, good lubricants and an oil filter, this engine, unlike piston
    engines that wind up to 8000 rpm will last forever and a day. Expect no
    depreciation on a Bergman Turboshaft.
    Reciprocating engines are more than a hundred years old. They were great
    on the Constellation, the most beautiful airliner every created by Man, but
    they are obsolete in today's jet age. Yes, its possible to keep doctoring
    them up with turbos, fuel injection and eight valves, DOHC, and what else
    they can dream up, but its time to switch. They are a dead end and nothing
    better illustrates that than the unparalled transformation coming soon to
    your Honda dealer in the form of gas turbine power.
  2. <Some crap>
    The Older Gentleman, May 14, 2005
  3. Nomen Nescio
    TaskMule Guest
    snip ridiculous spew
    What colour is the sky on your planet?
    TaskMule, May 14, 2005
  4. Don't you recognise a troll, you twerp?
    I'll agree with one thing, though: the Connie, and especially the Super
    Connie, the stretched version, was utterly beautiful. I'd suggest,
    though, that it might *just* be pipped for the title of most beautiful
    airliner ever by this:
    http://www.imperial-airways.com/De_havilland_dh91_albatross.html
  5. minor
    We want you to go away and stop wasting our time, Mr. Internet Stalker,
    anonymous remailer posting, privacy invading TROLL!
    krusty kritter, May 14, 2005
