30K today
Discussion in 'UK Motorcycles' started by TMack, Mar 14, 2011.
  1. TMack
    TMack Guest
    Today the v-strom recorded its 30,000th mile. That's in slightly less
    than 3 years since I bought it brand new. The only problems to date have
    been a loose connection to the fan and a partially seized gear linkage
    (grit and snow). Both problems quickly and easily remedied. Otherwise
    its been faultless despite being thrashed mercilessly all year-round.
    I am now mulling over whether or not to replace it with another new bike
    but I can't make my mind up. I need weather protection, good range and
    the ability to cruise at 90mph (on autobahns of course) whilst being light
    and nimble enough for filtering in heavy traffic. Another 'strom?
    Versys? F800ST? Tiger 800? or perhaps something like a Shiver with the
    addition of a decent screen. The trouble is I really like the 'strom.
    It doesn't do anything spectacularly well but it does everything that I
    need it to and does it well and fairly cheaply. Its not that I gaze on it
    with pride or anything but I am wary of moving to something else and then
    finding that it doesn't feel as "right" for the kind of long-distance
    commuting that I currently do. On the other hand it would feel like a
    missed opportunity to own a different kind of bike if I just bought
    another 'strom. Decisions, decisions...
    TMack, Mar 14, 2011
  2. TMack
    keep the 'strom. Won't it do another 3 years & 30k? It's not like you
    haven't go another bike for long distance work, or does that just sit in
    the lounge?
    wessie, Mar 14, 2011
  3. TMack
    Gyp Guest
    When I was looking, Geo Whites had a decent deal on the 650 V-strom with
    luggage & ABS (GT model, not XP) @ £6k OTR, making it cheaper than the
    base & ABS models and about £1,500 cheaper than the XP
    Gyp, Mar 14, 2011
  4. TMack
    You can go for an extended play on my Versys at the BOSM if you like.
    I'll even pull the lowering block out and pull the forks down the yokes
    so you can try it at normal, not stumpy legged, height.
    Lozzo
    they churn out)
    Lozzo, Mar 14, 2011
  5. TMack
    Pete Fisher Guest
    I might get a 'Puig' screen for my Shiver before the French Run.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 14, 2011
  6. TMack
    TMack Guest
    I might do that - but then I'm depriving myself of the excuse to get a new
    bike! The ST3 is used for touring and I do a couple of thousand a year on
    that but its not quite ideal for commuting. My commutes vary from highish
    speed motorway work to slow filtering in dense traffic - usually over 200
    miles a week. The ST3 doesn't like slow-speed work in heavy traffic cos
    its a bit lumpy at low revs. Also, it emits quite a lot of heat when
    stationary, which is fine in winter but gets a bit much on really hot
    summer days.
    TMack, Mar 14, 2011
  7. TMack
    TMax, Silverwing or Burgman then.
  8. TMack
    TMack Guest
    I may well take you up on the offer. I had a quick go on it at last
    year's BOSM (I think it was then) and I liked it but it wasn't really long
    enough to get to know it properly.
    TMack, Mar 14, 2011
  9. TMack
    TMack Guest
    In many ways the Shiver looks right for me in terms of price, performance
    and usability for my kind of commuting. The only obvious drawback is the
    lack of weather protection. The main thing would be to get a decent-sized
    screen on it as a longish run at 90mph on a naked in the middle of winter
    would be a bit too chilly. Someting like this would probably do the trick
    http://www.bikescreen.com/proddetail.asp?prod=ApriliaShiverSL750
    However, it's a bit fugly
    TMack, Mar 14, 2011
  10. TMack
    TMack Guest
    All around £8K new, which is too much money for not enough fun. If I
    were to buy new then I would want a proper bike.
    TMack, Mar 14, 2011
  11. TMack
    zymurgy Guest
    I doubt my Tiger will be at the BOSM, so there'll be no CIHAGM on
    that. Not sure about the Tiger 800, but the 955 isn't that good at
    filtering, [1] you need a nice V twin for that ..
    Paul.
    [1] heh, just mis-typed that as 'filleting'
    zymurgy, Mar 14, 2011
  12. TMack
    Pete Fisher Guest
    Hard to disagree. The Puig seems between that and the OEM screen that
    came with mine. They *look* like they should reduce wind blast a bit for
    motorway work, but middle of winter use isn't an issue for me. No
    problem with lumpy running in traffic on the Shiver - just flick the
    starter button when idling to temporarily switch the 'tri-map' to
    'Touring'.
  13. TMack
    I've test ridden the Tiger 800, it's a bit meh. It doesn't do anything
    any better than my Versys and has odd wheel/tyre sizes for a road bike.
    The only real plus it has is the complete lack of any vibes - it's very
    smooth but that also makes it seem a little bland.
    Lozzo
    they churn out)
    Lozzo, Mar 14, 2011
  14. Sounds like my mental processes when offer a cheap BMW R1200RT to
    replace the K.
    First thought: "Ooh, shiny! Bargain."
    Second thought: "Why bother? The K does the same job."
    The Older Gentleman, Mar 14, 2011
  15. TMack
    zymurgy Guest
    heh. You and that TOG. He called my Blackbird bland, the little
    tinker. As if you can call a 170MPH bike 'bland' ...
    Paul.
  16. TMack
    Mups Guest
    Have you ridden a CBR1000F...
    Mups, Mar 15, 2011
  17. TMack
    Yupp. I test-rode one whil I had the 955 Sprint ST, and yes, I thought
    it was bland, with a very indifferent power delivery. Up till about
    10k[1] rpm. But all the power came on way too high for me, and in more
    normal riding was distinctly underpowered, heavy and, well yes, bland.
    [1] Or whatever.
    Ace, Mar 15, 2011
  18. TMack
    Not ridden a Blackbird but I can entirely believe that. Power delivery
    is everything for the grin factor, hence a 60bhp 2-stroke will always
    be more exciting than a 160bhp 4-stroke.
    Krusty, Mar 15, 2011
  19. TMack
    Jim Guest
    That's odd - isn't it the same engine as a street triple?
    Jim, Mar 15, 2011
  20. TMack
    No - Street Triple's 675cc.
