400-4 bogosity.
Discussion in 'Classic Motorcycles' started by crn, Jul 18, 2009.
  1. crn
    crn Guest
    Took the beastie out for a pre-MOT test ride.
    Something is definitely not right, it has the flatspot from hell at
    around 2/3 throttle and after about 3 miles it could not even hold
    4th gear on the level without slowing. Seemed to be running hotter
    than expected, so I suspect that it was starting to nip up.
    Sounds like a carb/fuel issue to me, I'll take them off (AGAIN) and
    check that the main jet size agrees with the BOL and that no more
    crap has appeared in the float bowls.
    Grrrrr.
    Any other inspirations ?.
    Also the front brake seems a tad useless to me, less stopping power
    than the drum rear, I would have thought it should do better than that.
    crn, Jul 18, 2009
  2. crn
    Now that's not good.
    Fitted inline filters yet?
    Ultrasound cleaning of the carbs might be very helpful.
    Very carefully disassemble the whole mechanism including the swinging
    arm, regrease with the appropriate greases and once you made sure that
    everything is working as Sochiro intended, put back together.
    They should only be lethal in the wet.
    Timo Geusch, Jul 18, 2009
  3. crn
    mark Guest
    Wasn't raining was it?
    mark, Jul 18, 2009
  4. See if running with the fuel cap open makes any difference. A
    blocked air breather can cause similar time-dependent problems and IIRC
    they were mostly through the cap and easily blocked in that era.
    Upgrade to GS550B brakes. <g,d&r>
    Dr Ivan D. Reid, Jul 18, 2009
  5. crn
    Sounds like it could be a timing issue to me, so try the ATU. They can
    catch and stick sometimes, with odd effects. Also check that the
    points are a) the correct ones (mine weren't) and b) solidly mounted.
    They all do that sir. TOG always points at a seized mounting arm,
    which is supposed to swing freely. The one I had was fine in that
    respect, but still completely useless. A partial strip of the calipers
    revealed pads which looked like they'd fossilised a decade beforehand,
    plus mucho shit around the moving bits.
    Easily resolved, and with the addition of braided hoses to replace the
    near-perished originals, they were good enough to lock the front,
    although as the 10+yo tyre was about as grippy as a fried egg on a
    teflon pan that didn't take much. But it brought the braking ability
    up into the 20th century, at least, and made the front better than the
    rear.
    Ace, Jul 18, 2009
  6. If it's been off the road for a while it'll be bunged carbs, for sure.
    Poper ultrasound cleaning, new O-rings where appropriate, new needles
    and jets, the works. Budget a couple of hundred.
    The front brake can be made to work OK. The swinging arm pivot should be
    free, of course. The piston shouldn't be seized. Then it's a matter of
    steel hoses throughout.
    I've got a dogleg lever fitted to mine. Makes a difference too.
    At this point, if I were in your shoes, I'd recognise it's a money pit
    and break it for spares.
    The Older Gentleman, Jul 18, 2009
  7. crn
    I'd say you would have started breaking it a *lot* earlier.
  8. Heh. Well, I had enough sense not to buy the thing in the first place.
  9. crn
    crn Guest
    Indeed, but our objectives are maybe different.
    To me the fettling is the hobby and the challenge. As a pensioner I can
    spend endless hours tinkering to keep me busy instead of sitting in
    front of the idiot's lantern.
    I may have bitten off a little more than I can sensibly chew with this
    one but time is on my side. Eventually all of the impossible bits will
    show up for peanuts on fleabay and be replaced. I may lose a little
    money but the journey and experience will probably be worth it.
    The carbs will be stripped again and very carefully cleaned. I must
    have missed something last time. I suspect that an inline filter is
    required to stop shite getting through from the tank.
    First, however, I plan to try draining the tank via the tap to check
    that the flow does not slow due to a blocked breather. It could be
    that simple.
    crn, Jul 18, 2009
  10. Fair enough. But I can smell 'money pit' already.
    Um, now, they won't. Not for peanuts, anyway. I've noticed and remarked
    that good SOB spares are getting pricer by the year.
    Best thing to do is buy a donor bike, take what you want, and flog the
    rest. Seriously.
    That's a good idea.
    I doubt it. I really, really doubt it. So many people parrot "blocked
    breather stopping fuel flow" because they've heard it many times
    themselves.
    In well over 30 years of messing around with bikes, hundreds of 'em, I
    have never, ever had it happen. Nor has anyone I know.
    The Older Gentleman, Jul 19, 2009
  11. crn
    <waves>
    I've had it on the T4 Tiger, as have others. Never on any other bikes
    though.
    Krusty, Jul 19, 2009
  12. crn
    You're not alone in this.
    Especially for popular bikes like 400 Fours.
    Trouble is that the parts that are likely to be duff will drive up the
    price of the donor bike, too. I wouldn't be surprised if the donor bike
    ended up costing the same or more and then turn out to be the better
    bike.
    Timo Geusch, Jul 19, 2009
  13. <Life of Brian mode>
    There's always one, isn't there?
  14. crn
    crn Guest
    You dont have a tank bag then .......
    crn, Jul 19, 2009
  15. crn
    Life would be boring if there wasn't. Tbf though the whole tank on T4
    Tigers is a disaster area. I think Triumph decided to stick all the
    bike's design faults in one area (with the exception of the early
    sprags).
    The cap has a stupid rubber one-way flap thing over the breather hole,
    which tends to **** up. The captive nuts around the bottom edge for the
    fairing bolts can start to spin in their housings if you let a dealer
    anywhere near it, which means drilling into the tank to fix them (&
    hoping you don't drill too far), & if you leave the tank off the bike
    for any length of time, it changes shape & won't fit back on again.
    They carried this crap design trait on with the T7 Tigers too - fuel
    guages that fail regularly & pick a level out of the ether when they
    are working, & fuel pipe connectors that break, spraying petrol all
    over the engine.
  16. crn
    Happened on Ginge's ZXR12 on a 2005 French trip. Would start OK, run
    fine for a bit, then splutter and stop, refusing to start unless left
    for five minutes. The breather tube wasn't blocked, but kinked, from
    something he'd done around the battery area a week or so earlier.
    The oddest thing was that he'd ridden all the way from the UK to
    Bergerac with (IIRC) no problems at all. Still, once found, the fix
    took all of 30 seconds and the problem never recurred.
    Ace, Jul 19, 2009
  17. crn
    Or ZRX, or whatever. The Eddy Lawson replica replica thingy.
    Ace, Jul 19, 2009
  18. Heh. Good point. Yes, I do, but it's never blocked the breather.
    I've had a tank bag strap block the airbox inlet before, though. That
    caused some head-scratching.
  19. crn
    the wizard Guest
    Hi there,
    When your engine was running a bit sick, did your check the exhaust
    pipes to see if all cylinders were running. If 1&2 were hot and 2&3
    were cold or vice versa, check coil/points.
    T.W.
    the wizard, Jul 22, 2009
  20. crn
    Speedgazebo Guest
    It has happened to me.
    Back in 1977 I spent a very pissed off night pushing an ST70 from
    Kilburn to Harrow only to to find in the morning that the petrol tank
    cap breather was blocked. Yes, blocked, not turned to the closed
    position.
    Speedgazebo, Jul 26, 2009
