400-4 starting problems.
Discussion in 'Classic Motorcycles' started by Ace, Apr 27, 2004.
  1. Ace
    As per subject, I can't seem to get the bloody honda started at all
    and am completely stumped. There's fuel and spark, the points were
    new, and correctly adjusted, a few months ago, so I can't think what
    the problem is.
    Tried it with and without choke, cranking sometimes for 30 seconds or
    more. Taken plugs out (wet, they were), cleaned, heated them through,
    replaced - no joy. Repeated, leaving for ten minutes to dry engine
    out. Still no joy. With no choke there's just the very occasional hint
    of it firing, but really not much.
    Anyone any ideas? I'm wondering about a new set of plugs, but it would
    seem unlikely that they'd all go off at the same time, wouldn't it?
    Anything else I've not thought of?
    Ace, Apr 27, 2004
  2. Ace
    the problem is.
    Ace, Apr 27, 2004
  3. Ace
    M J Carley Guest
    I've had problems with the plugs (on a 550/4) that turned out to be
    carb trouble.
    Take the air filter out?
    M J Carley, Apr 27, 2004
  4. Ace
    ß Ø ® G Guest
    coils are on the right way around ? one goes to the other plugs and
    one goes to the inner plugs. Try new plugs anyway always worth it.
    Timing 180* out ?
    E-Mail Addy obet(ng)qfy(qbg)cvcrk(qbg)pbz <---Rot13 it
    watch out for spam trap in header
    Free Phone Unlocking
    http://unlockme.co.uk
    10p a Picture Message/MMS
    http://www.mmsit.co.uk/
    http://www.davessite.co.uk
    Trike Power the TRUE Trinity
    ß Ø ® G, Apr 27, 2004
  5. Ace
    Ta, but this is a bike that was running fine a few months ago and has
    just been sitting for a while. I'll try new plugs though.
    Ace, Apr 27, 2004
  6. Ace
    Hmm, there's a thought. I did buy a new one last year but haven't got
    round to fitting it. I'll give it a go tomorrow, ta.
    Ace, Apr 27, 2004
  7. Ace
    Geoff Berrow Guest
    Water in fuel?
    Geoff Berrow, Apr 27, 2004
  8. Ace
    Hmmm, it's a thought. Or some other shit, perhaps. Dunno if I fancy
    stripping the carbs just to clear them out though... maybe I'll just
    run some fresh fuel through and crank it over, FWO, without the plugs
    for a while.
    Ace, Apr 27, 2004
  9. In uk.rec.motorcycles, Ace said:
    Wasps nest in the air box?
    Whinging Courier, Apr 27, 2004
  10. mind you don't overheat the starter motor.
    Austin Shackles, Apr 27, 2004
  11. Ace
    Aye, I've been trying to be careful.
    Ace, Apr 27, 2004
  12. Ace
    Brian Price Guest
    If the bike has been standing for some time you try stripping the carbs,
    cleaning them and using fresh fuel. Over a period of time the carbs can get
    gummed up causing all sorts of problems like float bowl needles sticking.
    Also fuel can go a bit gummy with some evaporation that leaves gums and
    additives behind in a higher than usual concentration
    Brian
    Brian Price, Apr 27, 2004
  13. Drain the fuel from the carb float bowls. Drain the tank, Put new fuel
    in. Try again.
    There's no sidestand ignition cutout or anything like that. My guess is
    stale fuel.
    The Older Gentleman, Apr 27, 2004
  14. Yep.
  15. Ace
    Rob Guest
    I think it was on Tue, 27 Apr 2004 09:47:18 +0200 that Ace
    I assume the battery is fully charged?
    If I don't use the Virago for a couple of weeks the battery turns the
    engine over OK and there's a spark, but the bugger won't start. Half
    an hour on the charger and it fires up first time...
    I've found that pulling the clutch lever in often helps if it doesn't
    fire up first time, not having to churn the gearbox over as well must
    reduce the load on the battery.
    Rob
    Broseley, Shropshire
    1991 Yamaha XV 535 Virago
    1997 Rover 623GSi
    Rob, Apr 27, 2004
  16. Do you know how a bike gearbox works?
  17. Ace
    Pulling the clutch in on the Guzzi helps as the starter is no longer
    turning the clutch and main shafts (the layshaft is more or less
    unaffected as it's in neutral).
    On the MZs pulling the clutch in certainly takes a load off the
    kickstart...
    sweller, Apr 27, 2004
  18. True. Same with BMWs. Don't think the average Jap bike is the same,
    though.
    Heh.
    The Older Gentleman, Apr 28, 2004
  19. Ace
    The Older Gentleman was seen penning the following ode to ... whatever:
    Pans are the same, though. Maybe it's a shafty-only affliction.
    Timo Geusch, Apr 28, 2004
  20. Ace
    Think about it ...
    sweller, Apr 28, 2004
